Old January 4th 2008, 18:07
elev8_dude elev8_dude is offline
Unhappy Multiple Oil filter Blow Outs
Need your help once again. Without having to drill and tap my sump, is there a oil pressure relief option for my 1915cc.
I have:
Stock Oil Cooler
Full Flow System
Remote Oil Cooler
Any help would be appreciated, my drive way and neighborhood streets can't take any more stains.
Old January 4th 2008, 22:17
Are you using a Fram HP1? Where is your filter located?
Old January 5th 2008, 15:00
Using fram PH8A. Its located behind the rear drivers side tire.
I'm also running 30 oil
Thanks for the response
Old January 5th 2008, 16:03
brujo65 brujo65 is offline
ck the oil pressure relief valve move freely
Old January 5th 2008, 16:05
Bruce2 Bruce2 is offline
30 what? 10W-30, straight 30?
What is your oil pressure?
Do you have stock oil pressure springs and plungers? Do they move freely in the case?
Stop using Fram filters. Their filtering capability is inferior to all other brands.
Old January 5th 2008, 18:17
Turbo Haraune2's Avatar
Turbo Haraune2 Turbo Haraune2 is offline
use a filter with internal relif valve
Old January 6th 2008, 05:13
1303R's Avatar
1303R 1303R is offline
had a new filter dump it's oil at work this week, guess what. it was a fram
the filter face has bent and the rubber seal blew out the side
Old January 6th 2008, 12:37
you have a oil relif valve stuck or a major oil block in the case, ck the hoses for the right flow you know in -in out -out
Old January 6th 2008, 19:25
I used to have customer cars with this issue, if they used locally made (to me) Ryco filters they would blow a few filters a year. I found using VW factory brand filters helped, like Mann & Kneckt (not sure about the spelling).
Old January 7th 2008, 00:43
Well I switched to a new filter with relief (K&N HP-3001) and switched oil to 20w-50.
As for the 30w I meant 40w and my mechanic has suggested I run that oil here in Florida.
My engine was recently rebuilt, so as for the internals, there is alot of new parts , rings/gaskets, etc.
The blow out happen on our first real cold snap. And from what I've read and asked 40w is not the best (to say the least) as 25-35 degree, morning start oil.
Thanks for all your help. Any help is always appreciated.
Old January 7th 2008, 08:29
The oil pressure from the pump is not regulated untill it comes back to the case and hits the spring/piston. Cold start up oil pressure can be very high.
The K&N HP3001 has a burst rating of 600 psi and the seal is crimped into the case 360 deg. around the seal. Some filters just have a groove for the seal to sit in. I had problems with this on cold start up untill I changed to the K&N HP3001. Note the Mobil1 filter is made to the same spec. in the same plant. It just doesn't have the handy hex welded on the bottom. I have not had any issues since I changed to these filters.
Old January 8th 2008, 09:32
Thanks for the response. I will keep an eye out for the Mobil1 filters on my next change. The K&N are a bit pricey in my parts. Thanks
Old January 9th 2008, 13:34
dirk.Gysbrechts's Avatar
dirk.Gysbrechts dirk.Gysbrechts is offline
this problem will be solved with an Oilpumpcover with pressure valve..
Old January 9th 2008, 16:09
Sorry not to familiar with the process and the part. How does it actually go on?
Old January 9th 2008, 16:12
this is my current pump
http://www.cbperformance.com/catalog.asp?ProductID=197
