Old April 19th 2009, 14:38
Mechanical brake booster?
Haven't seen one in a while and would like one. I recall its not much more than a steel plate made to the right dimensions.
Anyone know where to get one?
I now have about the right brake balance I feel (last track experience), but braking force is now a bit on the high side for my liking.
Thanks,
Walter
Old April 19th 2009, 15:09
Simon Simon is offline
Are you locking up the wheels? If so, a smaller diameter MC could be an option.
And maybe a pedal with a higher ratio is an option?
Old April 19th 2009, 15:54
Originally Posted by $aint View Post
Are you locking up the wheels? If so, a bigger diameter MC could be an option.
Nope, like I said above, brake balance is really good now, but pedal force to brake to the verge of blocking is too high. I need a booster.
Yes, that is what I am looking for. I know it exists and its a simple item. I hope some company made some for a good price
I looked, but could not find one with some of the bigger US company's. Hoped s/body knew the right company who has them.
Old April 19th 2009, 17:09
Found a picture of it in the old Tafel catalog:
Old April 19th 2009, 20:06
Xellex's Avatar
Xellex Xellex is offline
Hoffmann-speedster.com has it listed on their website:
www.vw1303s.com
Old April 20th 2009, 13:30
Cool! Nice find! Looks like exactly thesame
Anyone have experience with this?
Old April 24th 2009, 22:03
kafercup kafercup is offline
I have one of those in the garage that has yet to be installed. I've had it waiting on the shelf for several years. It seems to be a well-designed piece. Once the ca is back on the road with the new 944 turbo front and rear setup (with 944 m/c) i'll make the decision as to whether the car needs it. With the old 944 n/a setup, my pedal was pretty stiff and the booster would have been a welcome addition.
Old April 27th 2009, 06:47
evilC's Avatar
evilC evilC is offline
Whilst the mechanical booster will reduce the effort on the right leg it does seem to be a piece of kit to cure the symptom not the problem. Wally, you either need a stronger right leg or a smaller master cylinder, which for a 30% reduction in pedal effort should be around 16mm or 5/8" (0.625). I would have thought that for a car used so extensively on the track that you would have gone for a balance bar set up that would not only allow the simple change to the master cylinder but also permit very fine tuning of your brake balance for different tracks? Adding yet another linkage on the standard system will only reduce pedal feel.
Old April 27th 2009, 10:09
This is how we took care of that problem on the Herbie X. It is an expencive setup and tok a while to get it installed. But the owner thinks it was the best mod we did to the car (and we moded everything).
It is a Tilton 600 3 pedal set-up. It totaly changed the way the car feels to drive.
Old April 27th 2009, 10:45
evilC's Avatar
This is the one I have been drooling over. It is on my list of fabrication jobs to do. As I see it the pull cylinders have a number of advantages:
http://www.apracing.com/info/product...F%3E_2351_2342
1) No binding therefore smoother opperation
2) The cylinders are within the shell and not out in all the crud
3) The balance bar set up with various m/c's will allow tuning of the brake set up.
AP have very kindly offered the detailed installation drawings on the web page so taking much of the guess work out of the fabrication. Also, I have lifted the floor infront of the pedals on the '03 Super, which I highly recommend. It makes the pedal operation MUCH more egonomic and comfortable with none of the foot lifting that you get with the standard car also there is a better relationaship with the seated position. That 50mm void then provides the space for the m/c's
Such a pedal box arrangement would be well within Wally's capabilities I expect.
Old April 27th 2009, 15:47
That AP setup looks sweet too.
Old April 27th 2009, 16:48
Hehe, well, don't overestimate my 'capabilities' nor my wallet as AP is usually very pricy (but nice)
I was/am hoping to be able to get the stock pedal cluster to work as well as I can be when I had just the rear n/a 944 brakes and everything seemed ultimately perfect untill I had to 'upgrade' again
The idea was to reduce front pedal braking and up the rear a little more (they now have the largest cups I could find for my rear disks) so the rars would lock up first.
The fronts have smaller cups than the rears now! So I got a brake bias adjuster from Tilton to regulate the rears. But nooooo, the fronts still (just) block first still, so its actually pretty good balance without any adjustment, except for the pedal force...
Old April 27th 2009, 17:54
Humble's Avatar
Humble Humble is offline
Hey Dave, what did you guys end up doing to mount the pedal assembly? I talked with you over the phone but I never got to see the finished results. The tilton 600 (and similar assemblies) are by far my favorite and I can't wait to get mine in the new chassis.
Old April 27th 2009, 20:34
If you can see in the pic, we raised the flood with .080 2024 t-3 and some spacers on the mounting bolts. The rods were extended thru the bulkhead (holes cut and spacers inserted) the M/C's are on the forward side of the bulkhead. a flat sheet of .100 2024 t-3 is on the bottom side of the pan. Bolts thru all layers stiffen things up nicely. It took a while to get it all in the way we wanted to but the end result made the owner very happy. The Tilton techs got the M/C size selection right on the money. We put the bias bar right in the middle and tested it in the parking lot of the owners building and never touched it again.
I want a set in my car some day.
Old September 13th 2009, 18:35
You have lifted the floor by 50mm?
Why did you choose 50mm (and not 30 or 70mm for example)?
