Old April 11th 2011, 08:48
Chris Percival's Avatar
UK Germanlook 1303 for sale
Type 4 engine, Porsche brakes, many top-spec custom parts
It is with regret that I have to sell this car. This is the first car I ever owned. It went through various modifications before getting a type 4 engine built by me, and a full nut and bolt rebuild a few years ago. Its based on its excellent original chassis which has only had the battery tray replaced. The body was profesionally painted by a local body shop. If your looking for a very quick, and superb handling German Look beetle, this is the one for you. Its handling is finely tuned with adjustable struts, front and rear suspension bracing, and front mounted battery, resulting in a 55/45 weight distribution. The large Porsche rims fit neatly under the stock size arches due to perfect offsets. The snug seats, race harnesses, sequential style shifter and Porsche steering wheel make it a very comfortable and engaging ride.
Metalic grey 2-pack paint
Shotblasted and Por15 coated modified floorpan to accept exhaust silencer forward of rear wheels
Aero style fuel filler
Carbon look mirrors
Custom front airdam with vent for oil cooler
Aluminium rear spoiler
Front mounted battery
Engine / Gearbox
VW Type 4 2000cc
1800cc style case
2000cc crank
94mm pistons/barrels
1800cc heads race prepared by MicroGiant - 41mm x 34mm valves
1700cc rocker shafts with Ford Courier swivel foot valve adjusters
Straight cut steel cam gears
34mm Schadek highflow oil pump
215mm flywheel
Dual 45mm Dellorto carberettors with rampipes
Porsche 911 Fan/Alternator with custom fan shroud
1/2 litre deep sump
Pertronix electronic ignition module
BAS exhaust header with custom silencer
VW AT code 4 speed gearbox
Suspension
Standard 1303 IRS chassis modified to house exhaust silencer
Custom adjustable struts with 90lb springs
BugPack front and rear uprated anti-roll bars
Custom & Speed Parts aluminium strut brace
22mm rear torsion bars with Koni gas shocks
3-piece Kafer-Cup brace
Brakes and wheels
Porsche 944 hubs machined to take beetle bearings on stock drum brake axles, Porsche 993 4-pot calipers and 290mm x 24mm vented and cross-drilled discs
Porsche 914 rear discs with VW Mk4 Golf rear calipers with modified Golf handbrake cables
Goodrich Stainless braided brake hoses all round.
Stock master cylinder
Porsche Cup 2 alloys 7.5"x17" ET65 and 8"x17" ET52
Interior
Cobra Aqua 4x4 seats
Sparco race harnesses
Porsche 944 steering wheel
Stock rear seat
Pictures, full restoration and build blog at www.fastbug.net. Car is located in Bristol, UK.
£5995
Old May 30th 2011, 21:53
aircured's Avatar
aircured aircured is offline
Can't use links
Sorry can't view any of the pictures through the links...
'72 Type 1 - GT
'69 Type 2 - Bay
