#1081
Hi Wally, is the water tank for water injection?
#1082
Yes, actually it has 50% methanol content.
#1083
Hey Wally, I've got 100% methanol right now, any reason I should or shouldn't be running 50/50 mix?
#1084
Too much, too long explanantion with many arguments on the practicle and performance side to the why of that, sorry. I've have come to the conclusion 50/50 is best. YMMV
#1085
#1086
...plus 100% is flammable.
#1087
The (non-visible) flammable part is one of the many reasons not to use 100% or even 75% meth iirc. At 50/50 is non-flammabe anymore as well. Not sure where exactly the border is, but its a moot point. |
#1088
Last week I took the engine apart as I wanted to have the case machined for a different cooling system (more of that later when its all worked out) and another cam to try out.
Good thing I did as all bearings and heads, pistons, cylinders were still in tip-top shape, but the rods were surely not! ![]() One has had a movement is 2 directions, but two others were just bend one way Before discussions start if this was the limit of stock rods: NO, its not; this was all caused by boost-cuts of the ecu causing huge back fires that even snapped two rockers if you can remember ![]() ![]() Fortunately Jake still had a set of slightly used Pauters, so those are underway
#1089
Does this mean that you got another set of 1.7-1.8 spec rods?
Or are you going to be getting a crank upgrade? I look at those "stock" rods, ANd there sure was a lot of nice work put into them. Nice trophies for sure!
#1090
Not yet, but these are underway
![]() ![]() Quote:
![]() The problem is the cylinders had to be cut back very short so its doubtfull 8mm more stroke is seen as still safe for how far the pistons will come out then... But I am sure you know what would have my vote Quote:
#1091
wow, I can't believe the rods bent so bad, that it's very visible in the pictures.. and still nothing failed.
www.vw1303s.com |
#1092
Is the crank still straight?
Braden |
#1093
Don't know yet as I haven't got the sort of equipment to measure that myself, but crankshaft is spotless and must be straight as all main and bearings were super nice as well:
#1094
Wow. Looks like you caught those just in time. They are wall hangers for sure.
#1095
That coulda been messy! Good thing you tore it down!
| Currently Active Users Viewing This Thread: 35 (0 members and 35 guests) | |
