#196
I'll keep that in mind.
#197
Today I started by fixating the front wheel (brakedisk) at the wright camber and caster.
![]() ![]() Made the innerwing mount to fit the innerwing, fixate everything again and made the first tackwelds. It's coming along just fine I think. ![]() ![]() Paul.
#198
The above picture of the shock dome on the simple 0.8mm thick inner fender does raise the question (I am sure you expected this, but I'am willing to bite anyways) what further stiffening of the inner fender your planning? I know its not load bearing like with a 1303, but still the shock dampening creates considerable forces nontheless.
#199
Wally,
Yes, the innerwing is deff. not strong enough. But the rollcage will solve that . The rollcage-tubes will run from under the dash to the upper shock mount and ends in the spare wheel well (on the front a-arm mount)Cheers, Paul.
#200
That deffo seems like the right way to do it!
#201
The horn bracket had to move, no suprise what was under there.
![]() So a little repair was needed. ![]() The right front suspension is ready (for now), so it's time to start doing it all again on the left side. ![]() ![]() Paul.
#202
Change of plans. I wasn't happy with the A-arm mounts I made in the spare wheel well, so I took out the grinder and started all over again.
No way back now. ![]() ![]() Made a new spare wheel well bottom. I will make a lower part in the middle for the battery. ![]() ![]() ![]() Paul.
#203
The new plan is getting shape.
![]() Paul.
#204
Today I copied the right A-arm mount to the left.
![]() Now it's time to weld it, grind it and weld it in place. Paul.
#205
Wow! Any clarification why you made as you did?
Curious how it turns out. |
#206
![]() Only one thing springs to mind, now is a good time to add plenty of caster.
#207
Paul.
#208
#209
Spare wheel well is in place and welded, almost ready for the next challance
![]() ![]() ![]() ![]() Paul.
#210
Nice! very dedicated pick-up points you made.
| Currently Active Users Viewing This Thread: 4 (0 members and 4 guests) | |
