#1321
![]() And here I describe how I created the A pillar deflectors: Reducing Windnoise / Raingutter Fillers page
#1322
Ok, so I disposed of almost all of the type 1 stuff and started cleaning a type 4 case again
![]() The idea is to use my 74mm Oettinger crank coupled to a moderate bore of 98mm to give 2230cc or almost as 'big' or small as the old motor was. This time with "someones" billet type 4 heads with T1 exhaust ports (if all plans and promises are met) for improved flow and strength. ![]() ![]() Almost everything on the engine will be a little stronger or better in some way, so I'am curieus what the outcome will be! Last edited by Wally; December 22nd 2017 at 05:55. |
#1323
Good to see you back into it Wally!
http://www.ricola.co.uk |
#1324
Good to see that you are continuing your quest, keep us posted with your progress
#1325
watching this one with a lot of interest. with what you proved with the last engine and the knowledge you gained from it this could be a very impressive motor.
#1326
Welcome back Wally! The billet heads will be introduced this weekend so I´ve heard. I´m really looking forward to this!
#1327
What type billet heads?
#1328
#1329
haha come on Walter, you have me chomping at the bit, who makes the heads do you have any pictures sir
#1330
Similar like these E Plus heads at cal-look lounge..?
![]() ![]() http://cal-look.no/lounge/index.php/...html#msg271836 |
#1331
Definately similar, but surely not the same
![]() If the manufactorere says ok, I'll post some pics of the drawings. Heads still need to be made.. |
#1332
Can that case still be good after being subject to the past abuse?
Spread center main? Pounded out/line bore needed? Dying to see how the case looks. That last crank was a stock 1.7, right? Just balanced, no counterweights, IIRC. If you can just use the case as it sits, it would speak very highly of the setup.... |
#1333
The crank was indeed stock 1,7 re-hardenend, polished and balanced. Nothing more. This time it will be 8mm more stroke, chro-mo forged & counterweighted ![]() ![]()
#1334
I look forward to more riveting updates from you Wally.
#1335
Cheers mate!
Left: new case have bolts (12.9, 10mm diameter) Middle: Original head studs (7.2mm diameter) Right: Raceware head studs (9.0mm diameter)
| Currently Active Users Viewing This Thread: 6 (0 members and 6 guests) | |
