Old May 26th 2014, 16:02
Originally Posted by effvee View Post
944S anti rollbar
Hi, the coil over shocks with the upgraded mountng bolt. I have read and read again where this coilover shock is great as a secondary assist. However the stock torsion bars are better. I would add the 944 sway bars. Man I sure wish this courld be really nailed down. I have three sets of 944 trailing arms, one with the sway bar; all early version (snubbers), as to which is better/stronger. Please believe I'm not trying to rain on your post, I love it, I just have questions.
I have real reservation about cutting into the torsion bar housing. In order to, for me lesson the possibility of a 915 trans fitting. I have reserved possibily using a much weaker in poundage torsion bar and the coil oves. The ideal of the 902, because of length, knowing that it has a weak first gear; rather than touching that strong point in the rear suspension. Even when they modify by cutting out areas, gives me the shivers about breakage in the exact area.
This Porsche bolt that you use for the lower coilover mount will be all that support your car/ride height. Will this be a dialy driver?
Hi Effvee,
I understand your concerns but I wanted the original width. using 7J fuchs and aluminum trailingarms meant I had to cut the torsion tube.
the lower shock bolt is disined to carry the weight, this is why i bought it and not use a home made bracket.
All comments are apprecieted
It will not be a daily driver. it will be my "good wetter" and VW meeting ride.
Paul.
Old June 4th 2014, 09:02
Rear of the car is now adjustable. Coilover set-up 3.0 is now finished
Paul.
Old June 18th 2014, 15:18
Today I reached a new milestone. The floor is of to the sandblaster to get blasted, metalized and get some undercoat.
Paul.
Old January 10th 2015, 10:36
luggage comp. raised and cage surrounding fixed. only needs welding now.
Paul
Old January 11th 2015, 08:10
nice work Paul!
Old January 11th 2015, 12:05
Thanx, it's all in the details Walter
Old January 11th 2015, 13:12
Absolutely! It great seeing someone taking their time to sort the details out. I usually don´t have that patience...
Old January 17th 2015, 11:23
A good friend started welding my cage today.
Old January 17th 2015, 16:59
Shock Top mounts are clever Paul, like it....lots.
Old January 18th 2015, 05:03
Thanks, hope they work.
Old January 19th 2015, 10:25
I'm sure it will be fine, The loads are well distributed in your design, brilliant height adjuster idea, but the lower bolts would keep me awake, I know they are super tough, but could you not run a tube through the arm, TIG weld it in and through bolt it?. as if you don't have enough to do already lol.
Old January 19th 2015, 17:03
That is an option, but they are designed for this and I am not the only one using them.
Cheers Paul.
Old February 14th 2015, 21:26
SuperRSi's Avatar
SuperRSi SuperRSi is offline
Those arms in much heavier 944/944T race cars are running pure coil-overs and that single shear bolt on their arms. I am doing the same in my Bug and have no thoughts drilling or welding the cast aluminum arms. If I was that worried I would rather replace the arms with the heavier Mendeola arms. I am working on making the upper shock mount double shear on two chassis now and will post on my build thread as it plays out.
Old February 21st 2015, 15:26
My thoughts. I'll be watching your thread as well.
Old June 6th 2015, 16:58
it's bin a wile but i'm still on it.
raised boot floor almost ready.
paul.
