Old July 29th 2016, 02:28
Clatter Clatter is offline
Will 944T brakes fit under 16" Fuchs?
Was wanting to fit Early Cup-style 16x8 and 16x7 wheels on my type 3..
The 8s are just too wide..
Love those 16x7 and 16x6 Fuchs from the 911SC and such..
Will those wheels clear my 944T Brembo 4-pot calipers?
I know I'll have to run narrowed arms, and likely spacers to deal with the offset,
But how much (if any) spacer will it take to get the wheels to clear those calipers?
Anybody ever try this one?
Old July 30th 2016, 23:52
flat flat is offline
Alot of spacer, about 18- 20mm.
The 951 part number 16"fuchs will fit without spacer as the spokes allow for the calipers. The 911 pn ones will require alot of spacer
www.vdubengineering.com
Old July 31st 2016, 12:11
Thanks for the quick reply.
I'm guessing that the 951 part number ones are from the 944?
Those that are typically black-centered, anodized rim?
Are you sure they come in 6" wide?
All I can find seem to be 7 and 8..
They do have a slightly different look than the 911 ones, right?
Instead of the rim being flat around the edge where it meets the center,
The 951 wheels are dished a bit, and have a bevel, like the 7" rears?
The rear 7s fit no problem,
But you have to deal with the offset,
Like narrowed arms and short axles, right?
Thanks again for sharing the wisdom!
Old August 1st 2016, 22:33
Yeah the 951 (944turbo) only came 7 and 8, both 23mm offset.
The modern offset wheels +52 to +55mm will fit better and clear the calipers, if you like the look.
Old August 1st 2016, 22:35
Good link here:
http://rennlist.com/forums/924-931-9...fferences.html
Old August 6th 2016, 10:29
Bad bug's Avatar
Bad bug Bad bug is offline
Hey Lanner. Good to hear from you. I need some help. I want to run porsche cup2 rims and porsche big red brake kit, can i run this under stock fenders with stock size axle beam, if i am to run wide fenders how wide will they be. I really am not interested in running a narrowed axle beam.
Old August 6th 2016, 12:31
1.5" is typical in front
Old August 7th 2016, 17:20
Bad bug's Avatar
So the rear wouldn't need wide fenders running ET55 rims.
Old August 7th 2016, 17:43
Not on 7" wide
Old August 8th 2016, 00:03
Bad bug's Avatar
Ok. I see where some guys run the 944 steel trailing arms on thier beetles, but taking a closer look at those arms they are just the same as the beetle IRS arms. Why the change if they look the same. I am also going to assume that they are the same.
Old August 11th 2016, 14:48
The Porsche steel arms have internal strengthening..
Old August 11th 2016, 16:45
H2OSB H2OSB is offline
Is that confirmed? I've heard that a million times, but no one is ever willing to cut up the 944 arms to prove it.
johnL (aka H2OSB)
Old August 11th 2016, 23:39
Ive never been brave enough to find out, seems like a waste of good parts. Maybe one day
But also there is a difference in the hole layout where the TA connects to springplate due to the adjustments available on 944 that are not on bug.
Old August 13th 2016, 09:17
Yes, I've cut mine open as I needed more clearance for a coil-over.
http://www.ricola.co.uk/images/cabri...m_internal.jpg
Old August 13th 2016, 10:51
Damn it! Now I need to get a set of those.
johnL (aka H2OSB)
