Old October 2nd 2024, 02:32
I'm not sure if the part number will help but these are the model cars that it fits
Old October 2nd 2024, 02:41
Having trouble posting pictures
Old October 2nd 2024, 02:45
A friend of my son is doing some fabrication for me. First thing he did was make intake pipes for the supercharger using the Mexican end castings
Old October 2nd 2024, 02:52
trying again with photos
Old October 6th 2024, 20:51
ian godfrey ian godfrey is offline
That guy can weld and the 'packaging' looks very neat, lots of thought on your part.
Well done
Old October 6th 2024, 23:30
Thanks. Ben is very good at welding stuff. He used to work for Hypertune
Old November 13th 2024, 00:07
Intake pipe done with DBW
Old November 14th 2024, 04:35
looking nice and plain!
Old December 23rd 2024, 04:26
I’ve been spending a bit of time on my Oval.
Its now running a 1916 with a SC12 supercharger, Haltech Nexus2 ecu and drive by wire and a Flex fuel sensor to run E85.
Its running a 4-inch narrowed beam with Monroe air shocks and bags on the back
Old December 23rd 2024, 20:06
owdlvr's Avatar
owdlvr owdlvr is offline
That looks absolutely fantastic
'71 Type 1 - Rally Project
'75 Type 1 - Family Heirloom
Old December 27th 2024, 01:49
Old January 4th 2025, 20:36
I'm not sure if this link will work
https://www.instagram.com/reel/DEY1p...F5NWpldWZ4ZDFm
Old April 8th 2025, 02:01
I had the Oval tuned the other day on a dyno at Tunesmith
Engine specifications
1916. Stock heads 110 Engle cam (not ideal for a supercharged motor) and 1.25 rockers, Vintage speed exhaust. 4 LS coils, Dubshop crankangle sensor and CB cam position sensor. Haltech Nexus 2 ecu. 485cc injectors with a 5th injector before the supercharger and drive by wire.
SC12 supercharger with custom pulleys.
Best 98 RON run was 98.5 kW or 132 hp at 5550 rpm and 80% throttle.
We then swapped to E85 and did a few power runs but a gasket leak at the inlet manifold prevented anymore power runs, but it still made 108kW or 145.6 hp at the wheels on 90% throttle.
The best thing about the drive by wire is that the throttle can be used to limit boost. The drive by wire is also used as a rev limiter, it rolls the throttle off near redline before a fuel cut
I'm using Mexican efi manifolds that were modified by Ben Wallker from Third Strike Fabrications
Old April 8th 2025, 02:03
Photo taken around 1am news day before loading he car into the trailer
Old April 25th 2025, 10:53
72marinablue's Avatar
This car is so cool Steve, loved the instagram video you posted.
1972 1300 GL In Progress
