Old November 10th 2003, 19:50
TitoRay's Avatar
TitoRay TitoRay is offline
Advice On Engine Rebuild
Well, a nut that was on my carb mount rattled off and fell down the carb throat then manifold and into my engine causing it to freeze. I currently have the car at the local shop. According to the shop a rebuild is neccessary. They say $1200-1500. What do you guys think about this price? Or, do you recommend, while I am at it, have it sent to a "professional" engine builder and have a few extras done. In the end, it all depends on the price, always going for most bang for the buck. So, who, what, and where do you guys suggest? Thanks.
1974 1303
Old November 10th 2003, 22:22
craazy Cooter's Avatar
I had a nut from my air cleaner stud fall into my # 1 cylinder once.
I took the head off, the piston ring lands were straight, and I replaced the head. The carbs were Dell 34mm frd 1 barrels. The bottom of the air cleaner studs had star washer nuts. BAD IDEA!
They got locktited in and the exsisting nut was thrown away. I still have the crushed nut. ()
