gauges, which ones?
i want to insall modern gauges. im thinking auto meter, but what gauges do you really need?
1 speedo 2 tach 3 oil pessure 4 oil temp 5 head temp 6 fuel 7 volt did i miss anything? im having a hard time finding a series with a head temp. im sure the gauge wont say head temp, but wht should i use? im thinking about the ultra lite series. any suggestions? if you monitor oil temp, do you need head temp? thanks neil |
Yes, Head temp and oil temp are 2 totaly diff. things. You can have high head temp and norm oil temp.
You could add EGT to the list.
EGT? what is this? im not familiar.
neil |
Exhaust Gas Temp.
I use head temp oil temp volts oil pressure and AIR FUEL RATIO
gauge by cyberdyne in conjunction with a 4 wire heated O2 sensor. You can't go wrong with this combo and some crazy carbs (and a tuning fetish)! |
That works.
