Old March 14th 2004, 21:25
Massive Type IV's Avatar
Send it on down, all your other items are ready.....
Jake Raby
Old March 16th 2004, 20:59
yetibone's Avatar
yetibone yetibone is offline
Sent it out this evening (Tues, 16). It wouldn't fit in the corner mailbox so I sent it FedEx. Should be there Friday or Monday.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old April 21st 2004, 16:36
oldblue72 oldblue72 is offline
oldblue
Yetibone !!
Don,t forget to check the oil pump surface and the stump surface before you get it all together I haven't forgot my ordeal with to the oil leaks I had on my engine, It wouldn't hurt to double check the cam plug surface also.
Im sure you know , But It dont hurt to remind . (talk is cheap)
Old April 21st 2004, 20:33
yetibone's Avatar
Thanks for the thought Blue. I bolted the halves together, and straight-edged the pump surface after removing the rest of the oxydation from the case, and running it thru a Cuda wash cabinet.
I still have lots of time to make it right before putting it together. My cylinders are out being re-sized for the pistons, heads are being ported, and big valved, the car it's going in is STILL down in the woods under a tarp, and my garage is full of moving boxes, and furniture .
I anticipated this being a summer project, but with all that has hapened to me since February, it looks like this will be next winter's project
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
