Old December 14th 2005, 19:12
75superAVW 75superAVW is offline
Help !!!!!
i remolded my dash and when i took it out i forgot to mark the spedo wires. i got the top of it but i cant get the oil, alt, and turn indicator to work. can anyone help . It is a 1975 Super thanks
Old December 17th 2005, 06:55
Try this link for a color wiring digram.
http://vintagebus.com/wiring/
the Oil Press, Atl, and turn ind. require power to the speedo with one wire then each ind. light get a ground from their respective sender or the flasher.
Old December 17th 2005, 12:11
The guy that runs that website is from Sacramento. He has a really nice bus, but he also has two bad @$$ 911's. One of the 11's is setup for racing. I used to work across the street from him, well I was heading home. Not doing anything crazy just cruising when all of a sudden i heard the pitch of the engine change. I let off on the gas then goosed it, all hell broke loose. Pulled over, opened the deck lid. Aluminum was everywhere, and a valve stem was sticking out of a intake manifold on my 1641. I very nicely done Super pulled over to see if I needed any help, and a mean 911(vintagebus.com guy) pulled over, he was rocking a VW hat. Moral of the story, if your gunna run 044 heads throw away the made in china SS valves and put in some Manley's.
PS sorry about jacking the thread
Old December 20th 2005, 06:55
Thanks for your help but i actually figured it out shortly after i posted this thread. i guess i was just making it more complicated than it needed to be
