Old December 6th 2002, 00:16
danielzink's Avatar
danielzink danielzink is offline
I think my gearbox is hosed...
I took the motor out of the notch tonight and what do I see ?
A puddle of gear lube in the bottom of the bellhousing. I was definitely gear lube and not engine oil - by the consistency and smell........The input shaft has a TON of play - both side to side and up and down.....
Whaddya think ?
Dan
65 notch 2300cc type4
www.danielzink.com
Old December 6th 2002, 13:58
kdanie kdanie is offline
Shot bearings that support the input shaft, time to go through the trans.....
ken
Old December 15th 2002, 06:14
njv's Avatar
njv njv is offline
hi
ive got the self same problem the question is will just a new output shaft bearing fix it ? or am i chasing my tail.
anybody out there allready done this did it fix the problem imhappy building any amount of engines but ive never gone live on a gearbox as yet !
all the special tools in the bently !! scare the living crap out of me im not gonna buy them thats if i could even get them .
may just look for another gearbox thing is i might be buying into the same problem again!!!
neil verdon 66 sqr on irs.
