Old June 13th 2006, 14:45
jimby jimby is offline
2366 T4 parts and CSP carbon porsche fan kit
All these parts are brand new apart from the crankcase
Type4 Crankcase, cut for 103mm cylinders and for johnson lifters.
Johnson lifters and brass inserts, cut for porsche fan.
all NEW from Custom Speed Parts in germany the product codes match their website for more info
carbon fibre porsche style fanshroud NEW porsche alternator and fan and stainless strap198 240 400K
and rear carbon 'tinwear' 119 524 400K
T4 1.5Litre deep sump kit 115 181 415
new T4 oil pump stock 115 105 021A
new T4 Eurorace 3 stage dry sump pump (the last new unused one in existence supposedly)
Polished Billet oil filler neck and dipstick 115 359 000
Billet pulley 115 359 000
lightened 215mm flywheel 105 271 411
needle bearing for above 105 313 111A
Billet oil cooler bypass 115 301 018
oil filter block off 115 359 000
T4 straight cut cam gear set 109 015 401
and
1800cc heads (not worked or cut yet) SECOND HAND and will need working to suit
spare 1800 crankcase SECOND HAND AND NOT MACHINED
Ideally you would offer a lump sum to take the lot as it will get progressivly harder to sell the parts bit by bit, you understand. so for the meantime who makes me an offer to buy the lot will get first dibs. note: the EURRACE dry sump oil pump is worth £600 alone so if you dont want that im prepared to split that item off
£1800 the lot
£1200 all except the EURORACE pump
£600 for EURORACE pump
jim +44 07815 288850
hillingdon Middlesex England UK
