Old August 16th 2006, 12:29
davey1302s's Avatar
davey1302s davey1302s is offline
kerscher
Ok guys you probably heard it all before,
kerscher coil overs up front and koni yellow shocks on back of my 1971 1302s bug.
what offset of wheels do i need in order to run 17"x 7" rims all round under stock fenders,and recomendations for tyre size
how much should i be able to lower bug with the kerschers,
anyone got the same set up
cheers
Old August 16th 2006, 13:26
flat flat is offline
Lowering is subjective, I can suggest tire sizes:
205/40 F, 225/40R, 17x7 et40 (+-2mm) offset.
www.vdubengineering.com
Old August 17th 2006, 01:32
levi20AE's Avatar
levi20AE levi20AE is offline
my 17' BRMs replicas are 17x7 et 35 and bolt up just fine without any modifications to the stock trailing arm bolts or upper bump-stop arm. I measured the gaps with the 215/45/17 tires that were on the rear and found that a 235/40/17 will fit without rubbing.
70 Std. Beetle
03 20th Annv. GTI
