Old May 28th 2006, 04:58
02cab 02cab is offline
they boxter 1s would be great but could they be wired up? ive seen them going on ebay cheap ish,thinking 911 guages now
Old May 28th 2006, 07:40
SoCalGL SoCalGL is offline
yeah this has definately been an idea in my head thats be rattling around... a 911 gauge set up mounted in the dash would look sick....
Old May 28th 2006, 08:37
Bogara_ZO's Avatar
Originally Posted by 65Cabby
My car may be 2.3 fuel injected running big reds and 17" cup wheels but the dash looks nice and period, what do you think?.
Wow, dude!! This is the best example to show how to install guages in an old bug's dash instead of hanging them under it!! You have cut the dash but the feeling hasn't changed at all! really nice work :agree:
Old May 30th 2006, 18:34
65Cabby's Avatar
65Cabby 65Cabby is offline
Thanks guys
The gauges are autometer 'traditional chrome' parts no
2499 tacho
2522 pressure
2543 temp
the speedo then had it's pointer painted to match.
Yes the dash was cut but then the car started out as LHD so the whole dash has been replaced.
What you can't see is the little shift light just behind the base of the Fridolin steerng wheel. I've left uder the dash for just extra switches like the washer bottle , oil cooler fan and launch control switch... but that should be another post
Old June 16th 2006, 12:55
Here's my Carbon Joe CF dash. Just installed it last weekend...
Kafer_Mike
Old June 16th 2006, 13:35
Bullyboy Bullyboy is offline
What are you using for a fuse box Kafer Mike?
Is that color Gulf Blue?
65Cabby can you post more pics of the dash or send me some?
Thats the same gauges I want for my car.
Old June 16th 2006, 13:59
Yep, Gulf Blue. I'm using a Watson Street Works panel/harness...
Kafer_Mike
Old June 16th 2006, 18:16
oasis's Avatar
oasis oasis is offline
:agree: Beautiful :agree:
Old June 16th 2006, 18:52
tom'72's Avatar
tom'72 tom'72 is offline
Beautiful
indeed, looks way better then the mess under my hood
Old June 25th 2006, 07:03
EvilOval EvilOval is offline
Decided to make my own dash (It'll have CF accents where the gauges go as well as the little valley on top of the dash). I'm basing it on a 911's dash (purchased a dash section from a mid 80's 911) just narrowed a bit. I'm just debating on what I'm doing on the lower section (might use some ideas from a 1303's lower dash section). The gauges are standard 911 stuff that has been redone in a tan with red accents....but messed up on the fuel gauge and had to purchase a new unit (will have to repaint it).....and I'm currently looking for a new tach that incorporates a boost gauge.
72' 1302 Vert GL (T4 powered money pit)
69' Ghia GL (T1 turbo powered and in pieces)
Old June 25th 2006, 08:28
barls's Avatar
barls barls is offline
here is mine minus the wheel
and from the back
still needs to be tidied up
my complete sbug rebuild
if you dont believe that something so broken can be fixed have a look at the link above
Old August 17th 2006, 08:53
chris7ian's Avatar
chris7ian chris7ian is offline
here's mine:
Old April 2nd 2010, 21:56
itHaKa itHaKa is offline
Porsche 914 speedo in kilometers and 914 tank gauge , oil temp and press taken from an early 911 , i had no room for the Tach
Old April 3rd 2010, 01:21
CLKWRK's Avatar
CLKWRK CLKWRK is offline
My ghia, one day it will come out of the paint shop
GL ghia restoration:
Old April 3rd 2010, 12:38
bow's Avatar
bow bow is offline
dang brought back from the dead!
YEAH ITS GOT A HEMI
