Old September 1st 2006, 03:09
vwdave vwdave is offline
Questions on Whiteline Swaybars for Beetle Ball Joint Front End
Hi Guys,
Just wondering if anyone knows if whiteline manufacture a front swaybar for beetle with ball joint front end, that mounts in the same way as the stock one, just with larger diameter.
I have one of their race adjustable front bars, however I don't like the way that they are mounted to the end of the lower shock mount. In my case there is not even enough thread on the lower shock bolt to fit the supplied bracket with their kit.
If not Whiteline- what are the options for uprated front swaybars??
Thanks in advance,
David
Old September 1st 2006, 03:46
dubKustom's Avatar
dubKustom dubKustom is offline
Here's what I'm using: http://www.cbperformance.com/catalog.asp?ProductID=462
My bar is #2825, but if you have a very low front end it might be better with the "lowered" ones, they give you more ground clearance.
/Daniel
Type 1 -69 in Gothenburg, Sweden
70's German Look in the making
Old September 1st 2006, 10:24
Lazarus's Avatar
Lazarus Lazarus is offline
i got my rear whiteline from aircooled.net maybe they can help you.
Old September 1st 2006, 17:32
Bullyboy Bullyboy is offline
airspeedparts.com for mine
Old September 14th 2006, 01:59
speedy's Avatar
speedy speedy is offline
anybody know if whitline adjustable bars are available in england
cheers jon
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old September 14th 2006, 14:09
MikeVW's Avatar
MikeVW MikeVW is offline
I have seen larger sway bars in Hot VW advertised as 3/4 which is larger than the stock one and they also have the same bar for lowered cars which mounts in the same manner as the stock one.
Mike
Jack of all trades and master of none!
http://www.Type1R.com
Old October 16th 2006, 14:30
OldeFahrt's Avatar
OldeFahrt OldeFahrt is offline
Dave, did you "window" the brackets?
Aircooled Road Racers
www.shoptalkforums.com/viewtopic.php?p=768795#768795
