Old October 11th 2006, 23:33
The Pirate's Avatar
Shocks? Shocking!
Ok so now I need to ask some thing. I need to know what stiffnes my new shocks for the rear will need to be.
Here are the stats
1975 SB
T-4 engine
G50 0r 915 tranny
944 trurbo trailing arms early
944 breaks
Tires and rims undecided.
I will most likley need some stiffer torsion bars as well.
Any suggestions on torsion bar / shock combos for this ride?
Pirate VW Services is looking for weber IDF and IDA carbs "to far gone to repair". We are also looking for 74 Super Beetle and later controll arms that are to badley bent to use or repair. PM for details.
Sevice with a yarrhhhh!
Old October 13th 2006, 15:12
The Pirate's Avatar
Echo echo echo..........
Old October 14th 2006, 12:51
Get some aftermarket coil-over dampers, that way they will be fully adjustable to your needs and you can add springs if you fing the torsion bars aren't up to the job..
Rich
Old October 18th 2006, 04:26
Bruce2 Bruce2 is offline
It is my observation that you can go with a very stiff shock and still have a good ride. That's because a Beetle has a LOT of weight on the rear.
I found a pair of Koni Yellow Sport shocks on a 944 at the wreckers and put them on my Beetle. I set them at full soft, which is equivalent to a Koni red at mid setting. The ride is just fine.
Old October 18th 2006, 08:28
OldeFahrt's Avatar
OldeFahrt OldeFahrt is offline
Rich
Sounds GREAT! Where do I get those?
Aircooled Road Racers
www.shoptalkforums.com/viewtopic.php?p=768795#768795
Old October 19th 2006, 08:45
I presume you are in the US, then I guess hte best places to find advertisers are hot rod and kit car magazines, most of them use those types of coil-overs..
Here in the UK we have quite a few different manufacturers who will sell varying specs or even custom dampers. I've used AVO, Gaz and pro-tech in the past
Rich
Old October 19th 2006, 09:00
OldeFahrt's Avatar
Do you have any links? Model numbers? Specs?
Old October 19th 2006, 13:14
Look at Summit Racing's website, search for 'coilover shocks'. They've got a lots of stuff. They have a large selection, price is right, easy to get.
These are my QA1 double-adjustables:
Old October 20th 2006, 04:33
Google the above names. For rears, I bought coilovers that are 15" extended, 10" closed length, for 1.9" ID springs..
My preference is going towards protech at the moment, all aluminium body and built to order with springs for about £200, I guess about $300..
Rich
Old October 20th 2006, 23:40
Bug@5speed(US)'s Avatar
Rich
How did you come up with your specs/
Did you compare to a remmelle setup or similar..
Going similiar route.. any info appreciated..
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old October 23rd 2006, 03:47
For the length those are actually the same as a stock rear damper, I don't run extremely low so that works for me. If you go shorter you also get reduced stroke.
The two standard damper body sizes are to either take 1.9" or 2.25" internal diameter springs, the smaller ones fit, the bigger ones don't so easy choice there! The main clearance problem is to the trailing arm, also the size of the cup that the lower mount fits into.
For spring rates, there is a site that compares torsion bar diameters to coil-over spring rates which gives a good start for spring rates..
Hope that helps!
Rich
Old October 23rd 2006, 08:06
OldeFahrt's Avatar
Can you link me to the coil v. torsion chart?
Old October 23rd 2006, 09:25
http://www.tech-session.com/kb/index...x_v2&id=22&c=4
