Old March 1st 2007, 11:50
Rob's Avatar
Rob Rob is offline
Welding up the oilpan...
I have a spare oilpan and I'm thinking about shortening it.
I am by no means an experienced welder, and all I have is a hobby flux-core welder.
Do you think this is doable ?
I know Mikey did it, but he's a much better welder than I am... and I'm pretty sure he has a better welder too....
What do you think ? Hints ? Tips ?
Rob.
Old March 1st 2007, 13:24
You could always use a fuel tank sealer afterwards to fill any pinholes, I used rustbullet on my fuel tank and it worked fine...
Old March 2nd 2007, 20:21
bt1211 bt1211 is offline
Try JB weld over your seams.
Old March 2nd 2007, 20:34
j.p. j.p. is offline
Just make sure both surface's are clean no oil /paint/ put bevel 's n pieces w/grinder , practice on same thickness material always maintain travel speed/ angle of nozzle.
Old November 5th 2007, 23:36
Hoghead Hoghead is offline
Before I try and reinvent the wheel, does anyone have a drawing on the best design for oilpan shortening. I was thinking of one with "wings" like a Moroso style pan?
I want to give this a go rather than import a cast pan
Old November 6th 2007, 01:00
brujo65 brujo65 is offline
ck outfront motorsports for $270 with exchange you get the pan + pick up
ready to go
Old November 6th 2007, 01:14
Thanks but I am in Thailand and by the time I import one the cost doubles, never mind that exchange is impractical.
I need to do this myself
Old November 19th 2007, 22:56
oil pan drawing
Anyone have a drawing on how to shorten the oilpan, and adding wings to regain capacity?
Old September 26th 2008, 18:40
WataBug WataBug is offline
somebody online did have a drawing with measurements where to cut it n etc.. but i lost it and tryin find it again..
Old September 27th 2008, 10:49
Bug@5speed(US)'s Avatar
Bugat5speed, also makes one, just in case.
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old September 29th 2008, 23:04
C4 Metal Werks C4 Metal Werks is offline
Next month I'll be shortening a bunch of the up for a friend of mine. I think he charges between 150.00-175.00 without a core. You can reach him at michaeltevis@hotmail.com
Old October 12th 2008, 16:55
jakriz jakriz is offline
G'day guys
heres my shortened sump. I have made sure that it carries the same amount that the standard sump carries. 5 litres to be exact. WRX engines fail from a lack of oil as they are under oiled from the factory. if u shorten the sump & decrease the capacity, u may spin a big end bearing sooner rather than later.
My sump cost me $45 to make. $45 for the steel & a mate welded it up for me.
http://www.superbeetlesonly.com/foru...5_6_103994.jpg
http://www.superbeetlesonly.com/foru...95_6_83894.jpg
Hope this helps
regards
Jak
Maltese Falcon Racing
http://www.superbeetlesonly.com/foru...y&cmd=sc&cat=6
Old October 13th 2008, 05:38
Jak,
How much is yours shortened by? How does it look internally, did you keep all the original baffling? Please stick some pictures up when you get it installed! Do you plan on relocating the oil filter too?
Cheers,
Rich
PS I enjoyed your update on the aussieveedubber forum, nice to read about some real world experiences...
Old October 13th 2008, 14:45
I shortened it by an inch. This makes it level with the standard headers, I could see no point making it shorter then that. The standard oil filter & cooler stay in the factory position.
regards
Jak
