#31
I do most of my modeling in Autocad, then fine tuning using the performance trends software.
a few pics of my project |
#32
![]() ![]() based on Thundrbird components designed around 5" ride height, RC 2" off the ground, less than 1/8" movement of rc in 3 degree roll or 3" bump. I used all-thread rod in a couple place to bolt it together temporarily to check articulation. Built this for My lotus 7 replica excuse the messy shop I'll be doing something similar on my Bus once the lotus is on the road. I'll build my own spindles to use VW or porsche components/brakes front will use Beetle spindles with porsche components(on the bus that is)
#33
Super nice work there!
Pirate VW Services is looking for weber IDF and IDA carbs "to far gone to repair". We are also looking for 74 Super Beetle and later controll arms that are to badley bent to use or repair. PM for details. Sevice with a yarrhhhh! |
#34
Got my rear suspension completed (sans shocks and antiroll bar) and am pleased with the results. everything will be dissasembled and painted/powdercoated before its finished. But the design is plenty strong and will do well.
![]() ![]() ![]() Next go around will see a 914 transaxle in the center with its diff flipped, this will be in the rear of my bus.
#35
-ok then what about the 928 - use the gts disc -or the 964 turbo -use the spindles -and the upper a - arm - |
#36
better strenght and lower weight with a tubular A-Arm, plus its easier to set geometry if you are designing both A-arms rather than working around one with a predetermined length
but ya, the 928 spindle would be a good choice
#37
http://www.freewebs.com/dobergoose/page3.html http://www.freewebs.com/dobergoose/page4.html Jason
#38
a bolt on front suspension would be a great product idea, but from the perspective of ideals, the frame horn has to go, a completely new chassis would be even better.
Keeping the frame horn limits the length iof your A arms, which is not terrible, just limiting. the ability to use Longer bottom a-arms make dialing in your suspension geomery/design much better, you have less compromise, you can have reduced bumpsteer, ideal camber gain, and a well located and stable roll center, you don't have to choose one. if you were doing a 1 off custom chassis the 928 spindle would be a nice piece of kit. But for a bolt on front suspension, stick with the beetle spindle it worked well with the paralell trailing arm suspension, so it will translate well to a paralell eqyual lenght A-arm setup, or even an paralell non-equal length suspension.
