Old January 10th 2003, 17:37
paulgrey's Avatar
paulgrey paulgrey is offline
Thumbs up 17" or 18" wheels
Hello,
I have been reading the verious different threds in the forums, I have found all the information very helpful however I am at the moment looking at fitting a set of wheels to my 1500 (1970) beetle and am strugling to work out which offset and size wheel to use. I will go with a 17" wheel on the frount and from reading the other information a offset of 40 should see me right with a standard lenght front beam and redrilled front disks, Please correct me if I am wrong. Where I am having problems is in deciding whether to put 17's or 18's on the back, I think 18's would look cooler. The set of wheels that I am looking at come in an 18/7 which should fit my redrilled drums fine (again correct me if I am wrong) what offset should I go for on the rear? and will the 18's look good when the back is lowered down on them?
Look forward to your responce.
Phat cars = Skinny chicks !!!!!!!!!!!
Paul Grey
Auckland, New Zealand
paulgnz@hotmail.com
Old January 26th 2003, 02:44
Exactly
I think it will look VERY good! That is exactly what I'm planning for mine. A 1" difference in wheel diameter will fortify the agressive part of the Bug shape while not looking obvious a la Prowler and a few other hot cars. Sorry I can't help you with the offset, as I'm starting from a different reference point.
