Old January 9th 2008, 09:23
dub_crazee's Avatar
964 c2 vs 944T
Whats the difference in these calipers??
Old January 9th 2008, 11:50
I will only adress the rear calipers, as I know these best.
C2 rear: two piston type, 44mm, very light-weight, great brake action. I love them.
944T rear: 4-(small) pistons (28/30mm?), smaller pistons than 993 N/A rear (30/34mm).
Difference in brake force should be better for the 4-piston caliper, but I suspect it doesn't make much difference. I have used both, but on different cars...
Old January 9th 2008, 12:18
dub_crazee's Avatar
i have the 2 pots for the rear of my bug - glad someone else has used them - not seen many bugs with them
do the front calipers run the same disc ie 994T and 964
for the front i have some 964 c2 calipers, and to use them i would either have to modify a 944 hub and run the disc, or turn down a vw disc to use as a hub and run the 964 disc.
however if i want to use a kerscher vented front disc i have to use the 944T REAR caliper? is this right?
i really wanted to go with the kerscher front disc as this is an easy mod but from reading i cannot use my caliper on this disc, but can use a 944T rear caliper or a boxster rear caliper?
