Old March 29th 2008, 19:47
vwbao vwbao is offline
rear coil over conversion
hi, if you install coil over shocks is it posible to get rid with the spring plates at all?thanks
Old March 31st 2008, 16:32
split_trix split_trix is offline
have a look at creative engineering (uk) air kits, it would need to be something like AIR IRS ARM... i'm sure air kewld does the same
http://www.creative-engineering.com/...=3821032_27662
chris
Old April 5th 2008, 16:49
hi, i dont want to go with airshock setup.
Old April 5th 2008, 17:51
i know is was the trailing arm setup i was pointing to....its supposed to elimate the spring plates and thus the torsion bars
Old April 5th 2008, 18:03
I got you. may ask if you can just take out the torsion bar and just install a coilover shocks?thanks
Old April 6th 2008, 08:04
skywalker
I assume we talk about a car with independent rear suspension (IRS).
Yes you can take the torsion bars out and install coilovers.
No, you can not get rid of the sping plates, but you can replace them by uniballs.
-Luuk
Old April 6th 2008, 19:37
i have tried to order the uni balls from the remelle's and not even e-mails answered any body else had luck with them......
Old April 6th 2008, 23:42
You can try MBT, www.mbt-engineering.de. Uwe speaks good english.
T4 2666 1303s
Old April 7th 2008, 02:35
Purely from what I've heard about people trying to buy parts from Remmelle on here I wouldn't even try, real shame as it looks like they have some nice stuff...
Old April 7th 2008, 02:40
tom'72's Avatar
tom'72 tom'72 is offline
Emailed them about ordering rear shocks and no response, went with AVO coils instead and turned out a bit cheaper
Old April 7th 2008, 13:13
I was very happy wiht pro-techs, they are about the same price as AVO, Gaz and other steels but they are billet ally, very nice! They build to order so you can have custom lengths for no extra charge..
Old April 8th 2008, 18:28
Angelo Amato's Avatar
uni-balls....
www.red9design.com
do them now - got the first set on my car
Angelo
Type 3 Fastback
