Old December 29th 2007, 12:46
hho hho is offline
Smile does 7,5x 17 et 65 fit under stock fender 1303 ?
Hi all.
I have tried to search the forum but has not found the answer.
I am looking at buying 4 7,5 x17 " Porsche Cup 1 alloys, et 65.
But will they fit under a stock fender.
I own a 1303 73, have Kerscher struts in the front, the back is standard.
I am running 6x15 Fuchs in the front now and 7x15 Fuchs in the back, but have a 5 mm spacer in the front and a huge one ) in the back but they fit under stock fender.
Any help would be appriciated.
Henrik
Old December 30th 2007, 09:37
According to this application http://www.1010tires.com/WheelOffsetCalculator.asp the front should fit OK but you may still need your 5 mm spacer. I added your 5 mm spacer to the stock Fuchs ET
On the rear I would have thought that you wouldn't have needed a spacer at all with your Fuchs.
Old December 30th 2007, 11:06
vujade's Avatar
vujade vujade is offline
I dont see what you would need a spacer at all on the rear either...
I ran 7 x 17 with 55mm offset on the rear of my super with only a
8 or 10mm spacer.
I 7 x 15in fuch has 23mm offset (unless its a 911R wheel with 49mm),
so it shouldnt need any spacer whatsoever. Even with the 911R wheel
you would need even less spacer then what what I ran (8 or 10mm)
WinterJam 2010
Old December 4th 2008, 15:19
hurley209 hurley209 is offline
hi, can i get a 70offset cup wheel on the back of my 74 super?
Old December 4th 2008, 16:53
bamberjim's Avatar
bamberjim bamberjim is offline
hope it helps
I am running 65 offset 16x7 teledials on my cab with 944 n/a brakes and avo struts, the front lip on the wheel/arch looks just right, if it .5" on the outside of the rim i think you will need oversized wings (front) i reckon it would def be tight on you front struts to0
Old December 4th 2008, 18:45
on the front the wheel is a 55offset.
