Old June 15th 2009, 21:51
panic's Avatar
panic panic is offline
When I assembled the lot, I used bug bearings and the bug stub axles. Im gunna tear it all down and do some measuring.
Old June 15th 2009, 23:46
I wonder if you left the oil seal runner out, it fits up against the flange end.
Old August 10th 2009, 16:39
panic's Avatar
I did some tear down the other night.
I'm not missing any peices, but the play is still there. We've come to the conclusion that the bug bearings are narrower then the porsche ones (I think, can someone back this up?) So I need to eather get a spacer or get the 944 bearings and press them into the hubs.
When it came down to it, the spindle was comming to far in on the axle shaft by about 2.3mm, so the rotor was hitting the backing plate.
Here I have two photos to help.
Has anyones else had this issue?
Old August 19th 2009, 07:25
kombi211 kombi211 is offline
well it hard to tell in your pic if its the alum arm or the steel ones. If its the steel arms there is no difference in the bearing Porsche uses the vw part number 113-501-283 same as irs bugs if you have the alum arms then its a different bearing altogether 999-053-020-01.
Old August 19th 2009, 09:22
All the part numbers for bearings, spacers and seals are all VW numbers.
I wonder why they have different thickness bearing lock rings?
Old August 19th 2009, 12:26
here the page out of the 944 manual looks like thats how the set up the axle end play. hope this helps
Old August 19th 2009, 18:02
panic's Avatar
I have steel arms on my car fyi.
Thanks kombi that certainly clears things up a bit!
Old August 19th 2009, 21:47
Bug@5speed(US)'s Avatar
Gents,
I have a sorta related questions... Does VW make the equivalent of PET files for the superbeetle? With the exploded diagrams and part numbers? If so how do I go about purchasing or acquiring..
Thanks and sorry to barge in on the thread.
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old August 19th 2009, 22:46
yes they do its called ETKA and its a dealer program and can not be purchased . and it comes with a special hardlock you plug into your pc to make it work. There are some crack versions running around.Not sure how well they work.
but there is a program by etos the you can buy. here is a link http://www.epcatalogs.com/ETOS0307.html the problem is most of the part number for the older car say NLA but the pics are still there.
Old August 20th 2009, 09:49
That shimming with circlip is interesting, I wonder if VW did the same thing.
I had ETKA running on my computer when I was running Windows 98, I haven't bee able to get it running with XP. It worked fine.
Try this site for exploded views http://www.oldbeetle.com/pcat/epc.html
Old August 29th 2009, 17:18
panic's Avatar
Thread hijack at its finest
I found these on Kijiji the other day and I started to make a pants-tent.
If I had the money.. Shoot, if I had the money the car would have been done 4 years ago! haha.
Old June 25th 2010, 13:27
panic's Avatar
Hey I have a little update!
The peice I needed has been sorted, and I bled my brakes yesterday. The wiring is comming along slowly, but I'll toss up some flicks soon!
peace!
Old January 24th 2013, 15:30
panic's Avatar
Hey all, Its been some time since I'v logged in here and contributed!
I haven't been working on my beetle as much as I like but I got a few things done since I'v last been on here.
Old January 24th 2013, 22:33
Looking good!
Old January 25th 2013, 03:53
SportyBug SportyBug is offline
Cool build, I would have never seen it if you hadn't updated it.
I know it is a bit off topic but I would like to know more about the Passat steering column.
Does this add anything to your bug like tilting the wheel or is it just looks?
