#436
i was amazed at the differance the front splitter made to high speed stabilty on my race car. it will be having a new one for next year when it comes back out.
shame you missed out the 11's but you know there in the car.
#437
Looks to be smooth at 137. I might just have to cut one out for my car.
#438
Great vids Wally!
The car looks very stable at speed,nice set up! With that gear/tire/HP combo you can crack the 250Km/h.Armin ran 257 Km/h (digital speedo aswell) with my 90kg ass sitting along side.Rpm was approx. 6200 with a 225/50/15 tire 3.44 r+p and 0.82 4th. boost was about 1.2 bar.Wastegate was set at 1.3 bar. |
#439
Clutch is clearly at its power limit... :
#440
257 km/h is sort of crazy in a beetle on the highway/autobahn. I recalculated and that is 251 km/h, which is close enough. Crazy...how does his stay stable for that? He runs less aero then I do, but his car is also less wide, so maybe that helps some to gain the speed. Still, over 250 km/h is wow! Last edited by Wally; June 27th 2010 at 14:51. |
#441
Wow !
Is that a 6 puc Kennedy unit ? Have you looked at a dual disc setup ? I believe there is an advantage to 4 friction surfaces vs two for your power level. I'm looking in to it as well. Sandeep |
#442
Yep, that is, or better - was- a Kennedy 6-puck semi-metallic unit and a Sachs Race-engineering HD 228mm clutch (probably stage 2-ish).
They couldn't make me a organic twin-disk set-up (too thick), but instead I had to get the semi-metallic twin disk set-up with a G50 center. Hope it will still be driveble. Short of a stage 3, there are no options, so I went for that one. I ordered it with a stage 1 pp. We'll see if we can get it round my shortenend G50 spline... |
#443
wally,
One friend use this clutch (made usa) in one drag beetle with 900+ HP. He said it was very good. What do you think about this? ![]() Not found exactly the same on the internet. But the link below have one sample. http://www.horsepowerfreaks.com/part...o_Stage_5/7263 http://www.youtube.com/watch?v=IgLKqW74agE |
#444
That is a black magic clutch disc. A lot of higher HP vw guys use that disc with a stage 1 plate.
#445
I love this disc!!! Used to drag with, and can be freshened up by media blasting after a few runs. Almost like new. A little harsh on take off, but locks right up. Less harsh I found if hydralic clutch is used. also check out the Gene Berg dual friction disc.
#446
What is better than one black magic disk?
Two of them... ![]() Apperently kennedy use these to make their double disk set-up. This is what came in yesterday:
#447
That should work
Looking at your pics makes me realize once again what drag racing does to components...Quote:
#448
FPR and -6 AN upgrade:
![]() and of the fuel rails (drilled and tapped for 3/8 NPT):
#449
Wally, I'm loving the progress your build has made, sweet!
#450
Where do you take your MAP from Wally, have you drilled and tapped the manifolds?
Cheers Paul |
| Currently Active Users Viewing This Thread: 4 (0 members and 4 guests) | |
