Old June 24th 2010, 16:33
Mykul's Avatar
Mykul Mykul is offline
Mykul's car
Not really GL
Hi! This is my 73 AutoX car
I started my VW life with a 70 a Baja. The 73 was supposed to be a temporary car while my Baja got painted. I was only going to drive the 73 for about a month and sell it when the Baja was finished. That was over 3 years ago and the Baja is still not done. (But that’s another story)
Here are the stats:
1641cc
W110 cam
Kads – soon to be a turbocharged 40IDF
4 wheel disk brakes- just EMPIs, but they work
Droped spindles
¾ in sway bars front and rear
I AutoX the car in both Phoenix and Tucson. I am classed in SSM (Super Street Modified). I’m currently running mid pack.
Old June 25th 2010, 00:30
Komet's Avatar
Komet Komet is offline
Nice car! What kind of tires are you running, do you have any rubbing problems?
Also, do you have any oil starvation problems in the corners?
-Mike
'73 Supperbettle Sunroof
Old June 25th 2010, 02:07
Mykul's Avatar
Right now I'm running Kumos 195/50/15 in the front and 205/65/15 in the rear. They don't rub, But I did have to pull the fenters out a little. When I get some money, I plan on running 205/50/15 all the was around.
I over fill the engine a little, so I haven't had any starvation problems. The next engine will have a windage tray.
Old June 25th 2010, 12:23
Humble's Avatar
Humble Humble is offline
Tires and driving skill will make the biggest difference. 205/50 15 sizes are easy to find and very cheap. You should be able to find good R comp tires (semi slicks) for around 100 or so. If you haven't done so already find a better seat, something that keeps you in one place
Old June 25th 2010, 17:37
Mykul's Avatar
I haven't found them for less that $160, but I'd love some R comps. I'll have to see how my sponsorships pan out.
As far as seats, I have some custom ones on order, just waiting for them to be finished.
Old June 26th 2010, 18:01
hotsauce's Avatar
hotsauce hotsauce is offline
Mike!!!!! Hey, we need to get my car done so i can go out and run at the track w/ you...
just another square saltine.
www.garagejunkieapparel.com
Old June 26th 2010, 19:29
Mykul's Avatar
That, or you could co drive mine.
Old June 26th 2010, 19:56
hotsauce's Avatar
No, we need to get me sponsored and finish the build already. it hasnt been worked on in a year.
Old June 27th 2010, 04:48
Mykul's Avatar
A man once asked, "If you have hot naked women in one hand and a tub of jelly in the other, which do you choose?"
And the wise master (Joey Tribbiani) replied, "Put your hands together!"
You can co-drive AND build your car.
