Old February 5th 2011, 17:58
Fast65 Fast65 is offline
My G50 install
ive decided to go for the porka box a G50 box from a 1990 911 these can take at least 550 bhp so that should be able to take some abuse
the proka box next to a standard T1 box
now ive got to make this lot fit
well after 20mins with the plasma cutter does this
another 90 mins with the help of a 9" grinder gets this
getting some were now
front and rear mount done ive got fit the IRS brackets and sort the shifter out put some metal back were i cut it out and then i have to do is clean and paint it all
new flywheel and clutch fronm KEP so i can fit the T1 engine directly to the G50
Old February 12th 2011, 13:32
spent a few hours today getting the shifter fitted and the conneceted up to the box, i seam to be able to get all gears but i guess fine tuning when the engine is in and running
i shortend the shift rod by 35mm
i had to change the linkage to an earlier one
as the one on the box wasnt going to fit the linkage i have
the feel of the shifting feels a world away from a T1 box feels very solid and precise
cheers andy
Old February 13th 2011, 05:35
Going well, very nice.
Old February 19th 2011, 15:13
cheers thanks
bit more done today ive nearly finished the chassis know
fitting th IRS Brakets with a jig
starting to work out renforcing the forks
clutch slave cylinder pipe bracket
cheers andy
Old February 19th 2011, 16:19
effvee effvee is offline
What about the VIN Vehicle Indentifaction Number location? I know of the one on the Dash area, but the second one is right where you have removed. Won't that raise legal issues?
Old February 26th 2011, 15:02
it may but im not to worried i did not have much choice
bit more today
i dont think that will move woo hoo
Old March 29th 2011, 05:00
Jim Hunter Jim Hunter is offline
Actually you can shorten the nose cone as per 87-89 3,2 G50 and you will gain about 6-8 cm narrower nose cone...
But your work is also looks very nice,
Jim
Jim Hunter
74 1303 (GL project) *SOLD*
73 1303 (GL project II)
(VW T3s for sale.Panels, 2wd and Syncros)
Old April 30th 2011, 12:08
Jim
i did look into that but i thought i will still have to cut the torsion tube so the engine was in the correct position,
so this is how were looking now
cheers andy
Old April 30th 2011, 13:52
Bug@5speed(US)'s Avatar
Wow,
Looking good.. What front end is that.. Eyeball or other?
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old April 30th 2011, 16:20
hi
its a red9design from the uk
cheers andy
Old May 30th 2011, 15:20
major leep forward to day it swaped chassis
first time this has been off since 1965
I had to cut a bit more body work out to get the G50 in
but shes in
now the real work can start woo hoo
cheers andy
Old January 25th 2012, 13:49
Any more progress on this one?
Old January 29th 2012, 05:57
dub_crazee's Avatar
There is a big thread on vzi. jg54 section under 'turbo questions' - it's getting pretty mental!!!
Classic Car Revivals
www.classiccarrevivals.com
Old January 29th 2012, 09:11
cheers, I'll go and have a look!
