Old February 6th 2012, 22:30
Mendeola 5 kafer bar set
The kit is impressive and easy to install.
Great work, Thanks Kevin.
T4 2666 1303s
Old February 6th 2012, 22:45
owdlvr's Avatar
owdlvr owdlvr is offline
Photos or it didn't happen.
'71 Type 1 - Rally Project
'75 Type 1 - Family Heirloom
Old February 7th 2012, 11:45
oasis's Avatar
oasis oasis is offline
I'd like to hear impressions from the driver's seat as well. I am keenly fascinated by Mendeola products.
(2004-2008): 1971 1302 w/2056
Old February 7th 2012, 20:55
Looks like the photos cant be uploaded!
T4 2666 1303s
Old February 7th 2012, 20:58
Will takee more pictures, till then keep .
some problem with uploading the photos from the site.
T4 2666 1303s
Old February 7th 2012, 21:41
owdlvr's Avatar
If you email them to me I will host and upload them
Old February 23rd 2012, 17:32
coolrydes coolrydes is offline
Thanks for the kind words. Here is a link to our add on the samba http://www.thesamba.com/vw/classifie...php?id=1148596
And a link to our unfinished website DO NOT BUY OFF THE WEBSITE YET!!!! http://mendeolasignaturemotors.weebly.com/
Old March 5th 2012, 11:38
evilC's Avatar
evilC evilC is offline
Hi, it looks a professional piece of kit but I have two queries:
1) The top mount on the shock tower has a long plate and therefore M12 bolt. The node point of the bars is well inboard of the shock tower - doesn't that add a bending moment to the bolt?
2) Where does the torsion tube connection land, it looks further outboard of the frame horns that are the traditional fixing point?
Old March 6th 2012, 17:30
1) The top mount on the shock tower has a long plate and therefore M12 bolt. The node point of the bars is well inboard of the shock tower - doesn't that add a bending moment to the bolt?.....there was a lot of questions about that when we first introduced them. We then posted pictures and our findings. It takes more then 6 tons of presure before these bolts or brackets will bend.
2) Where does the torsion tube connection land, it looks further outboard of the frame horns that are the traditional fixing point?.....the front mounting point for IRS is the irs pivot bolt. For swing axle it is a bracket attached to the horn gusset.
