Old February 21st 2012, 13:52
Sweet. Another one saved and back on the road.
Old March 31st 2012, 21:04
vw1303's Avatar
vw1303 vw1303 is offline
Yeah got tires mounted.
Getting the rear tires on was something else. Lets just same there was fire involved.
Old March 31st 2012, 23:34
cookvw's Avatar
cookvw cookvw is offline
wheels are awsome. i also posted on your fb as well.
Old April 1st 2012, 03:58
owdlvr's Avatar
owdlvr owdlvr is offline
The ol' modified-propane-tank trick to mount the tires...or ether and a lighter?
Always fun!
Wheels look great.
'71 Type 1 - Rally Project
'75 Type 1 - Family Heirloom
Old April 1st 2012, 06:08
Xellex's Avatar
Xellex Xellex is offline
the first time I had that done on a set of wheels, it scared the crap out of me )
www.vw1303s.com
Old May 17th 2012, 16:29
vw1303's Avatar
Starting on some suspension goodies. Custom lower control arms are next.
I happen to stumble across these turbine shafts in the machine shop that suited my needs Material is 4140 and so it will be plenty strong enough and then coupled to that is a 5/8" Chromoly Heim Joint.
Old May 20th 2012, 18:32
vw1303's Avatar
Installed some of these 2psi residual pressure vavles. The brake pedal has the feel I was looking for and I now have the some confidence in my brakes.
The brake system now consists of:
-Stock master cylinder
-All new steel brakes lines
-Stainless braded flex lines
-Wilwood proportioning valve(installed on the rear circuit)
-1983 NA Porsche 944 front and rear calipers
-K sport Hydraulic Handbrake
-Empi 2psi residual pressure valve
Old May 20th 2012, 21:15
onixbonilla's Avatar
onixbonilla onixbonilla is offline
Originally Posted by vw1303 View Post
Yep they are Gotti wheels. Made in France back in the day. I was contemplating BBS RS as well but could never find a set for the right price. Those will look awesome.
Also couldn't resist this...
Running 1303 for $400. Going to fix a little brake issue slam it and use it as a daily driver this summer
If you are like most of us you will find yourself modifying this one also in no time!
Old May 24th 2012, 14:41
vw1303's Avatar
Sneak Peek at custom lower control arms. This is the inner. Outer will also be heim joint with a roll centre correction spacer for the spindle. Also need to figure something out for the sway bar attachment. These will be a bolt on unit.
Old May 24th 2012, 22:50
cookvw's Avatar
when you get these done, id love to be interested in a set.
Old June 26th 2012, 15:56
vw1303's Avatar
Cleaned up my trailing arms and made some new lower coilover bushings.
Im using a 1/2" precision ground shoulder bolts so this will get rid of some of the slop I was having. Also was looking into the rear coilovers I have and turns out they are Koni's over $500 a piece . Next up I am ripping out the stock diff and putting in a spool
Also while putting in the spool Im upgrading to Type2 CV joints and axles.
Old June 26th 2012, 16:11
owdlvr's Avatar
Can't wait to see the front control arm setup.
...oh and I should probably wing some springs down to you, eh?
Old June 26th 2012, 16:30
vw1303's Avatar
Hey Dave. Yeah that would be good to get the springs back. Bring them along with the rally beetle if possible. Also Dave I lost your phone number when I updated my phone. Mind sending that over again. I might need some pointers on setting up the new diff.
Old June 26th 2012, 16:34
owdlvr's Avatar
604 849 0076 - Shoot me a txt as I'm not sure I have your number on my new Blackberry.
Old July 6th 2012, 18:39
vw1303's Avatar
After some clutch chatter issues and wanting to keep things in place better I'm switching to solid mounts. I'm also going to reverse the rear cradle and mount the gearbox forward a few inches. Ditching the front rubber mount and going with a mid mount. I'm going to get rid of the urethane piece that the midmount came with and use aluminum and drilling through the frame horns to secure it.
