I need to STOP.....
It has begun.....
Stop teasing and put up some 'installed' pics
![]() Lanner |
Finished the brake install today - then test fitted the rims.
And yes ....I went against judgment and went with drilled rotors ![]() I figured the car is driven less than 3000 miles a year and I bought (supposedly) good ceramic pads so hopefully the dusting won't be too bad... Brakes on: ![]() rear: ![]() front: ![]() 4mm spacers needed front and rear as the rims were hitting the calipers: ![]() wheels on: ![]() rear: ![]() front: ![]() Dan Last edited by danielzink; November 18th 2012 at 22:04. |
Drilled brakes and 3,000 miles per year -- I don't foresee any overheating problems.
![]() Looking great!
(2004-2008): 1971 1302 w/2056 Searching for a new project ... |
Overheating isn't the issue though. I've heard (from a couple different sources - and researching on the web) that drilled rotors can lead to excessive production of brake dust. Not particularly good for your nice new rims - also - can just make a big mess on the side of the car etc. if it's really bad. I pretty much drive the car only to shows etc. - so I'll just keep my handy dandy duster brush with me at all times. Also - sources have said that a good set of ceramic brake pads can help diminish the dusting. Dan |
Very nice!
Wheels are a little too much bling for my taste, but the type fits the cars very well. Lovely notch and very cool rear bumper!
The drilling just helps stop the pads from glazing by inducing a bit more wear on the pads. They won't help with temperatures, in fact it will probably make them run hotter due to the lost mass. You're right about the ceramic pads though, they are for low dust...
http://www.ricola.co.uk |
I put it all together and dropped it on the ground today...first time the car has been on 4 wheels on cement in 3 years !
Still need to bleed the brakes etc etc....but it was exciting to see everything fit. The "bling-ish-ness" of the chromed rims seems to have been tamed down with the tires on and and the chrome trim on the car. ![]() ![]() ![]() ![]() Dan Last edited by danielzink; November 18th 2012 at 22:06. |
