#76
These in the pic seem shorter, more inbound travel possibility, which could be helpfull if you were to go even lower in the rear. Looks like Remmele coil-overs to me, but not sure.. |
#77
What about Protech shocks recommended by ricola?
For those with steel arms, they come in 1.9" which gives better clearance from the CV boots and reasonably priced.. you can opt for extended base, choose btw bushing or bearings etc.. But gotta check if they have springs higher than 400lbs..
Be water, my friend.. |
#78
You must 'design' your own shock with them as they will ask what dimensions you'll want and you will have to wait and see if what they make from that is what will fit and work.
I'd rather have a shock/coil-over strut that has proved itself on my application (bug or 944), but the price difference is huge, which makes it all the more difficult.. |
#79
Third set for aluminum arms is under construction, same as last
![]() ![]() AVO has also many shock lengths, i helped pick up coilovers from AVO for my friends homemade a-arm project for his 1960 beetle. http://www.demon-tweeks.co.uk/motors...oilover-damper Last edited by -Alex-; October 12th 2012 at 14:46. |
#80
Hi Alex I wondered if these would be a good match for your uniball set up ? regards Graham http://www.ground-control-store.com/.../II=749/CA=219
gee dub |
#81
Yeah, those are ok. They include necessary bolt extensions at bottom end. Choose atleast 450lbs springs, or better 500lbs. Ask from subaruengined beetle owners what springs they are using?
#82
Where can i buy boots like this? I need it in europe.
Best Regards kendy |
#83
I got mine here:
http://www.jjcraceandrally.com/kit-c...-cv-joint-boot
http://www.ricola.co.uk |
#84
thanks
#85
I have one set that its not complete, i can make a complete setup either for 944 aluarm or 944/924/bug steel arm for 650 euros, this offer is valid only up until next month or so
#86
What kind of alu do you use? 7075 or 2017A?
#87
I use 7075-T6 only.
#88
Is it too late to snap up that incomplete uniball set? I need it for 944T aluminum arms and correct me if i'm wrong but these will work with the stock porsche swaybay pckups that go through the arm and spring plate? PM with billing details
#89
Humble,
I'm running your setup and am curious about what you're getting up to? I am building my own uni's at the moment and would love to know how you're planning on using these parts? more info? |
#90
Who? Me? Humble?
![]() What you want to know? |
| Currently Active Users Viewing This Thread: 6 (0 members and 6 guests) | |
