Old November 8th 2013, 20:30
Rule09 Rule09 is offline
No it's just a 915 i better had used G50
Old November 9th 2013, 03:57
Bogara_ZO's Avatar
Very cool, can't wait to see more..like the stance, looks very aggressive right now with that wide rear track. Have you decided the color yet? What is your wheel/tyre combo?
Old November 9th 2013, 06:32
Thx! I hope the stance will be ok, the front is to high and the coilover are almost at the end at "lowest" i think i need shorter spring at the front..
The wheels are the 17" fuchs like you see on the pictures, but the tires probably toyo R888 or toyo R1R but that's for later..
The color will be something grey, flat or shinning, dark or light, i don't know yet but with carbon parts..
Old November 14th 2013, 13:34
subamaniac90 subamaniac90 is offline
Where did you get the aluminium top mounts?
Old November 15th 2013, 13:33
GPP Dirk Gysbrechts also on this forum..
http://www.german-performance-parts....id=500&lang=NL
Old February 3rd 2014, 10:23
I'm gonne ad 2 more and reweld the top the front one on the other side of the bolt..
And the last job was the must horrible one!
I didn't saw it when i bought it
And put a new dash in..
915 adjustment..
Old February 3rd 2014, 19:50
Your doing some good work, just a thought, maybe you should close up the vents below the windscreen so that you don't get any moisture in that area again.
Old February 4th 2014, 01:35
Yes it's a giod idea, i was thinking about it
Thx!
Old February 4th 2014, 03:13
The engine for the GL is a 2.7 typ 4 and is build in germany by Udo Becker..
It a project for the past 3 years.. The plan was to rebuilt my 2.4 in to 2.7 but after collecting al the part in germany the plan is to built a complete shortblock..
Brand new vw type 4 case..
Scat crank 80mm
Pauter..
udo becker drysump oil pomp
JE pistons
Udo becker heads..
Flywheel and clutch from sachs
And the latest update is a 6 bolt change on the case and heads..
The engine is almost ready so i can drive to germany and get it to my place..
Old February 28th 2014, 16:44
This morning i got a phonecall that my chassis was finish, sandblasted, metalised and powedercoated!
Got home and start with the rear and front suspension parts..
Old March 1st 2014, 03:03
Coming along nicely!
Old March 22nd 2014, 15:03
New update from yesterdag, moved the body and rented a sandblastingmachine!
After 4 hours sandblasting
And a friend helped me with painting epoxy primer
Finished inside
Pics of today happy with the result!
Old March 22nd 2014, 15:41
cookvw's Avatar
cookvw cookvw is offline
Looks awesome. I'm very jealous of your parts selection. Keep the updates coming.
Old March 22nd 2014, 17:06
SuperRSi's Avatar
SuperRSi SuperRSi is offline
Who made your aluminum front X brace for the front trunk area?
Old March 22nd 2014, 17:34
It's from Heigo
