Old November 6th 2014, 23:40
effvee effvee is offline
3:44 r&p
Hi, who makes the 3:44 r&p ? Albin transmission $10,000 for a one off.
Old November 7th 2014, 04:03
JIMP JIMP is offline
O.K this is what they need for this month to pay their bills? real bargain
Friendly
Dimitrios
Old November 7th 2014, 06:55
Hi,I guess it takes alot to change a bolt pattern in their process. Or just discourage me, well that'd worked. O well, I guess I'll have to go with a 915.
Old November 7th 2014, 10:24
OK sorry to discourage you, but hei, for that price you should be discouraged! check this out, maybe it works for you
http://cal-look.no/lounge/index.php/topic,23697.0.html
Friendly
Dimitrios
Old November 7th 2014, 15:15
It looks like Weddle sells them for Type 1 transmissions:
http://weddleindustries.com/products...ng-pinion-sets
Old November 7th 2014, 22:58
Ok, here is the issue, it's the Quaife diff. I've not seen the 3:44, but everyone says the 3:44 dimeter or bolt pattern won't work.
With a Rhino case built I would gain back some valuable spacp.
I had a thought of contacting Quaife ane see if they could sell a part, that the quaife bolt pa
attern would match. Man I sure would like to build that tramssmission.
