Old November 16th 2013, 00:06
SuperRSi's Avatar
SuperRSi SuperRSi is offline
So do the three funny shaped tab washers go above the shock tower and the rest below?
Old November 18th 2013, 14:29
Humble's Avatar
Humble Humble is offline
That's how I've seen them installed. It's also common to find 914 camber plates installed that way.
Old August 24th 2014, 13:50
Blizzard's Avatar
Blizzard Blizzard is offline
I got a set of camber plates for a mark 1 vw Golf from Silver Projects on Ebay. They are made from steel and can be easaly adapted to fit a superbeetle.
Original next to Silver Projects VW Golf camberplate
Cut up to join the 2 together
Finished adjustable camberplate and Original
Old September 4th 2014, 15:41
Blizzard's Avatar
Fitted in the car. I still have to make some sort of seal to close of the camber plate.
Before
After
Old October 22nd 2014, 21:00
Bugscandrift Bugscandrift is offline
Id love to know some more information on how you did that. How did you join the two together? Is the adjustable plate made from steel so that they can just be welded together? Did you use a hole saw to cut out the center of each? Love this idea!
If god had meant people to walk, whyd he invent cars?
Old October 24th 2014, 19:31
H2OSB H2OSB is offline
So, I contacted the guys at Silver Project to see if they could just add camber plates for Super Beetles to their line of products based upon Blizzard's idea above. They're going to. I talked back and forth with one of the project team members to determine what was needed. In the end, I sent an early style upper strut mount to them in Poland and they received it today. I should know soon how it comes out. Stay Tuned.....
johnL (aka H2OSB)
Old October 26th 2014, 06:57
Blizzard's Avatar
The diameter of the early Strut Bearing Mount, up to 1973 is smaller than the later Strut Bearing Mount for 74 to 79 Super Beetle. The hole in the body is also smaller. I have a '75 1303 so the hole is for the wider diameter Strut Bearing Mount.
The outside diameter of the Silver Projects Mark 1 golf camberplate is to big for the hole upto '73. So if you use the Silver projects camberplate based on the Mark 1 golf in a super upto '73 you have to make the hole in the body bigger to fit it.
> 1973
1974 >
Old October 26th 2014, 07:45
I sent the early mount and told them what you just said. Hopefully, he fully understood.
johnL (aka H2OSB)
Old February 2nd 2015, 02:19
The Silver Project guys came through. Here's is the new camber plates for 1303s
http://silverproject.eu/en/shop/susp...eetle-1974-79/
I'm must admit I'm a little confused. I SENT him an early upper strut bearing for the bolt spacing, and because the rubber/steel section is easier to remove from the early mounts (the later mounts are pressed from a single piece of metal). Perhaps its due to the fact they used the adjustable section from their Mk1 Golf mount and it fits into the hole on the later chassis cars (and according to Blizzard, above, does NOT fit through the hole on the early cars)(in fact, in one of the pictures, you can see the exact upper strut bearing I sent to him). Anyway, the price seems very reasonable to me. I will be buying a set asap.
johnL (aka H2OSB)
Old February 4th 2015, 23:45
Humble's Avatar
I've got a set on the way and I'll test them on my 73. I'll give a review once I have them in hand.
Old May 1st 2015, 16:45
proudbugowner proudbugowner is offline
Hi all!
Glad to be a member of this forum!
Has anyone measured what is the inside diameter and the width of the top mount bearing and wants to share? I am a bit lazy to unmount the shock in order to measure it
I want to machine some new spherical bearing top mounts and would like to know this diameter and width in order to determine what spherical bearings to buy and design the top mounts according to them... Any input will be welcome!
Thanks in advance!
Mario
