Old December 28th 2016, 17:04
Master brakecylinders and clutch cylinder are overhauled and mounted with the TILTON pedalbox.
The Steering column is mounted and connected to the R&P and it works like a dream..
Old December 31st 2016, 14:11
"tight fit"
Old December 31st 2016, 17:58
effvee effvee is offline
Nice taste
Old January 4th 2017, 23:24
Clatter Clatter is offline
Love it.
Excellent.
Old April 20th 2017, 16:21
It's bin a while but I'm still on it.
After setting the stance I found out that the front shocks where too short. the new shocks are gas filled and a bit longer.
I want the camber on the frontwheels somewhere between 0 and -1deg. but the adjustment did not go further as -2deg. now I will modify the Porsche A-arms. I will narrow them a bit and replace the original balljoint with an adjustable uniball.
Old December 17th 2017, 01:16
How is the build going?
Old December 17th 2017, 03:47
It is going very slow, I am renovating my house.
Old December 17th 2017, 03:55
Sorry, het staat vanwege de verbouwing van mijn huis op een laag pitje. maar wel wat gedaan.
Porsche draagarm uit elkaar gehaald
Nieuwe draagarmen maken voor betere afstelmogelijkheden, lager kunnen en smaller.
Centreerringen laten maken
Fits like a glove
Old November 10th 2019, 12:53
slow progress.
home again
new spare wheel.
made new a-arms with camber adjustment.
New (test) tyres
The test tyres fir perfectly.
Old November 15th 2019, 09:25
I like!
Nice garage floor BTW
Old November 7th 2020, 15:07
Due to small other projects, the bug was waiting in the corner. now it is time to start again/
Restored and sold a Vespa
Fixed and sold a Honda
Fixed and sold a 944
Old November 7th 2020, 15:09
Still not happy with the rearwheel alignment. time to order some monoball bushes and fix the problem. I always thought the driveshafts where a bit to long. today I checked and they are indeed to long, have to fix that too.
Old November 7th 2020, 17:29
Good to read an update!
Old November 12th 2020, 10:31
Check and like my page;
https://www.facebook.com/Vwrankenste...9015887687050/
