Old February 13th 2017, 05:52
effvee effvee is offline
PDK Transmission
Hi, does anyone know the dimensions of the PDK manual transmission?
Old February 15th 2017, 10:40
SuperRSi's Avatar
SuperRSi SuperRSi is offline
You would have to say which one...
Old February 15th 2017, 19:33
Helllo, the PDK transmission which I need its dimensions is the one from the Porsche Carrara, around 2015. It's the 7 speed, not the tiptronic.
Old March 10th 2017, 07:04
Well I got a response today from the excellence magazine editor concerning the PDK. it's too long for me to consider. Ok, back to the G50. I wish that I could have afforded the mods last year, it jumped 500$.
Any one know how much for a good trans manual cost?
O by the way the PDK is 27.5 inches in length.
Old March 10th 2017, 08:23
Just carve out the center section, make it fit! Although the electronics of it might put me off if it can't be made to work stand-alone. A true flipper-operated manual PDK would be totally awesome!
I would be more interested in its weight then size...
Old March 10th 2017, 23:39
Hey, when I first saw the PDK for me it looked shorted than the G-50. I really hoped that it was. But now I still want the EZ-36. So, even if I have to go with a 5 speed bug trans, and that 5 speed being a Berg, if I can get the EZ-36 the fit in, this will be my choice. The PDK, would take at least 8000$ just for it. Let alone the ECM interface concerns. I have a Rhino case gussetted. I can choose the Whiddle gears to match the G-50. My EZ-30 its without the oil pan and timing tran gear covers. I need to now get the meausurement. It's all about that 6 cylinder.
As a last ditch effort, I can get back on track with my three liter if all else fails. I choose not to go extreme in the axle tube area.
Old March 12th 2017, 01:33
Luismj's Avatar
Luismj Luismj is offline
Do you know any aftermarket control interfaces for PDK?
Thank you
CUP2 17x7x9 Brembo.w.Servo&Master.Cylinder/IRS/CB Dropped Spindle
GTI 2.1 16V Turbo Forged/Sapinho/Fueltech EVO-GL
Old March 12th 2017, 04:47
Thank you
Thats the right question!
Old March 12th 2017, 06:48
Good morning, no I do not know of any interface hardware/software. For me the primary hurdle was the dimensions. Guessing, RPM and throttle position, would be primary. If I we're to have made it fit, I would have started my interface journey with reaching out to a company like Motec. The fit, starter, flywheel,for me was first. I also would have cannibalize the donor car for the transmission ECM and any other parts that would made the transition more possible. From what I saw, the PDK had a sensor ring on the outside of the flywheel.
Sorry
Old March 13th 2017, 18:02
My G-50
Hello, since I have had to change transmission options, it's back to the G-50. The guy that sold me the trans is a co-worker. Per his statement, the trans had a posi in it. Well, I wanted to make sure that the trans had a posi; well it did not. For me its very important that trans had what it said it had. So now I have my lip stuck out I may just go for plan "B " and build a 5 speed bug with a Rhino case. It's sounding better by the moment
