Old August 6th 2020, 10:49
Bogara_ZO's Avatar
With all the Covid closures the local drag strip has decided to resurface the strip so I still haven't had the final tech inspection on my cage
I've entered a roll racing event at the Sydney Motorsport Park this coming Friday but the weather predictions aren't too good for that night.
I've fitted up my Mickey Thompson ET Streets for the event on some 18x9 Simmons OM wheels, they a 2454/40x18. Took it it for a kebab run the other night, they are hooking up nicely even though they have been sitting next to my garage unused for about 5 years
Looks good, Steve 👍
Old August 7th 2020, 19:43
Thanks. Roll racing was postponed due to wet weather until 21st August
Old August 23rd 2020, 10:24
finally got to go Roll Racing
https://youtu.be/oGQKTZghi0E
Old September 15th 2020, 18:48
I've been talking to my local Subaru tuner and AWD Subarus with similar specification motors to mine are making 360 - 380 kW at all four wheels.
I've been thinking that there must be a restriction somewhere in my setup, I'm running a Varex muffler and a water to air intercooler.
My ECU has an exhaust pressure map sensor so the other night my son and I did some extensiveness testing.
So 290kpa inlet, 350kpa exhaust On 25psi (eboost), so 1:1.2 which is quite acceptable.
We also checked pressure drop across the intercooler which was about 3 psi.
So now that I'm confident that my setup is not causing issues I'm going back for a touchup tune with some more timing and boost as suggested by the Subaru tuner.
Old September 16th 2020, 06:22
Old November 8th 2020, 19:17
Fitted up my track wheels with Toyo R888R on them to see how they would look. They are genuine hollow spoke 7.5x18 50 ET and 18x8 52ET
Old November 8th 2020, 21:49
H2OSB H2OSB is offline
Gorgeous Steve. What side mirrors are those?
johnL (aka H2OSB)
Old November 9th 2020, 03:02
Thanks.
They are local XY Ford Falcon mirrors that I modified to fit, they look cool but are a bit small. A link to a local website that sells them https://www.fordmuscleparts.com.au/s...keyword=mirror
I cut the bolt on base off and and had it welded up and I used the the stubs from VW mirrors so that I didn't need to drill any extra holes.
The people standing with my car, are me and Dinos son Valentino, then Dino who is a member on here and another friend of mine Barry.
I organise a VW cruise on the 1st Friday of the month (Der Erste Freitag) at Harry's Cafe De Wheels
Old December 19th 2020, 19:52
Weighed my wheel collection the other day
6 inch Cookie cutters with 205/50 x 15 Mickey Thompson ET street et = 15.7 kg.
6 inch Cookie cutters with 185/55 x 15 street radials 13.8 kg
Hollow spoke twist 8 inch with 235 40 x 18 Toyo R8888R = 20.5 kg
Hollow spoke twist 7.5 inch with 225 40 x18 Toyo R8888R = 19.7 kg
Boxster 5 spoke 8 inch with 225 40 x 18 Nitto Invos = 21.2 kg
Boxster5 spoke 10 inch with and 265 35x18 Nitto Invos = 22.4 kg
3 piece Simons OM 18x9 with 245 40x18 Mickey Thompson ET Streets 22.8 kg
Old January 15th 2021, 18:55
Another day another dyno run
This was on a hub dyno, same tune that made 319 rwkWon rollers made 350 rwkW on the hub, difference being no wheelspin. The dyno operator confirmed cars that don't wheelspin make just about identical power on both his Mainline dynos
The dyno guy didn't have 5x130 hub flanges so I bought these 130 to 114.3 adaptors from eBay
Old January 17th 2021, 14:53
Nice results again!
At what boost pressures are those lines? Green line is 14,7psi or so?
He's missing out a lot of work not being able to dyno 5x130 haha!
Old February 2nd 2021, 04:46
Low boost was about 22psi.
interesting point, same tune that was on rollers made 319 and on the hub 350, so just 1 psi of boost and more timing it made 32 rwkW more.
The waste gate is fully closed now at 31 psi so out of turbo which is what I wanted to achieve
Old May 7th 2021, 01:00
I've been running 245/40 x 18 Mickey Thompson ET streets, these were 2nd hand and pretty old and the side walls don't have a lot of give.
A local speed shop had a special on some M&H 245/55 x 15 drag radials.
There was no 15 inch Porsche factory wheel that would work because my wheel bolt face is pushed out a long way by my 944 trailing arms so I had a pair of 15x6 Cookie cutters widened on the inside to 8.25 inch to take these tyres. They worked out at ET 65.
My local tyre guy did a finger balance rather than a cone balance for me
Old May 7th 2021, 03:19
Nice! I had the same done to a set of 5,5Jx 15 spare wheels towards 7,5J. Was meant for 24x8 drag tires full slick.
Let us know how you like those pls!
Old May 7th 2021, 18:52
they would have looked really cool.
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
