Old July 10th 2003, 09:42
Bugnutz's Avatar
Bugnutz Bugnutz is offline
Lightbulb Diameter of 944 turbo front hub
Hello all-
Can anyone supply me with the outside diameter of the Porsche 944 turbo front hub? These are the ones where the brake rotor 'hat section' fits on from the outside in normal fashion, as opposed to the NA type hub where the rotor was mounted inboard.
I am thinking of using my 5x130 studded Ghia rotors as front hubs for bigger brakes by cutting off the original disc, leaving me with a sturdy cast iron hub with no bearing hassles. Besides, I already have them.
The ghia hub section diameter measures approximately 170mm.
Any help here would be greatly appreciated!
Regards, Mark (Bugnutz).
Old July 10th 2003, 10:08
I did a similar thing, Im not sure about the diamter.
Steve C
Old July 11th 2003, 08:57
Bugnutz's Avatar
Nice...
Steve-
That's some really nice work!!! Thank you for posting the pic.
-Mark.
Old July 11th 2003, 09:27
Superman
This company www.powerhaus.com machines early Porsche hubs to accept the later disc's hat. They should be able to help you with some measurement specs.
Old August 19th 2004, 15:54
rip's Avatar
rip rip is offline
hows it going I know its been a few year but....
how did it go machining the old rotors work?
thanks
rip
Old August 19th 2004, 21:47
SuperRSi's Avatar
SuperRSi SuperRSi is offline
Steve C,
What size holes did you drill into your discs? The look huge!
Thanks,
Randy
Old September 7th 2004, 10:00
Bugnutz's Avatar
went in another direction
thanks
rip
Hey, sorry to be so long with a reply. I decided to save the ghia stuff for another project, and went with a pair of billet hubs and caliper adapters to fit on BJ drum brake spindles from VDUB CUSTOMS. I'll let you know how it works out.
Bugnutz
