Old August 10th 2003, 16:32
Bad bug's Avatar
Bad bug Bad bug is offline
type 4 case
Can anyone tell me how to check a type 4 case for wear. What should i look for.
Old August 10th 2003, 18:37
Massive Type IV's Avatar
Center main collapse
mike the align bore
check the thrust surface of the #1 main bearing
check all lifter bores
check for "The syndrome"
I go into it a bit in Volume 8 or Bug Me video, the TIV rebuild.
Jake Raby
Old August 16th 2003, 17:37
yetibone's Avatar
yetibone yetibone is offline
Jake,
please elaborate on what "the Syndrome" is if you would. I think I have heard that term used before. I too will be building a Type IV soon and need to make sure the case I have is OK.
Thanks,
Yetibone
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old August 18th 2003, 22:28
73notch's Avatar
73notch 73notch is offline
the syndrome he is referring to is when a former owner of the engine overtightens down the bolt that holds the oil plate on, on the bottom of the engine, thus causing the engine case to crack in that area.
Old August 19th 2003, 00:21
Pillow's Avatar
Pillow Pillow is offline
i do not think so. If it is overtightened it breaks, period, which is obvious to see.
No biggie as it can be welded back up in short order.
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
