Old August 26th 2003, 18:42
steven erwin steven erwin is offline
Question 944 Trailing Arm From An 83
CAN I USE MY VW TRANS AXLE WITH AN 83 944 TRAILING ARM?
WHAT IS THE ADVANTAGE OF USING THE 944? :silly: WILL THE BACK TIRES STILL BOW OUT?
Old August 26th 2003, 21:40
Pillow's Avatar
Pillow Pillow is offline
The only advantage to a 944 arm is that it will have a larger stub axle that you can use for beefier T2 CVs. You would just need Thing output flanges to get the inners to match.
But if you have a mild engine the T2 CVs are not needed.
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old August 27th 2003, 17:12
:haveadrin THINKS FOR THE INFO. I HAVE A 1900CC. I SHOULD BE OK FOR A WHILE. THANKS AGIN!!!
