Check to see if the shocks are at full extension. If I understand you correctly, you are try to make room for a towbar but the adjustment is too low. I had the same problem, but I removed the top shock nut, let the spindles fall to the desired height, put the front back on the ground, and reattached the shock nut. I hope this helps.
thanks Scott My Blog Please help me get a minimac Parts I Need 1965 Beetle "Gordie", 1956 GL Beetle |
Thread Tools | |
Display Modes | |
