Old October 22nd 2003, 00:40
blue4400 blue4400 is offline
Longer Cylinder Barrels
Hello:
I'm building a long rod stroker.
2110 T1 = 82crank +90.5pistons+ 5.6 rods
Who makes longer barrels? How much do they go for$$??
Old October 22nd 2003, 13:17
petevw's Avatar
petevw petevw is offline
i made a 1/2inch spacer out of T6 aluminum, and put them between the barrel and case. i believe you could buy longer cylinders and machine them down. i think they are called "century cylinders". try:Kevin Shull
i'm running a 84 crank with 5.7 rods.
'72 super
'65 bus
'52 split
Old October 23rd 2003, 07:15
Tim Tim is offline
I guess Autocraft make extra long barrels. VW Speed Shop in UK market both Autocraft and Century barrels.
http://www.vwspeedshop.co.uk/pg/cataloguepages.htm
Tim
Old October 23rd 2003, 07:41
dgluyas's Avatar
dgluyas dgluyas is offline
Longer Barrels
"Heads up performance" in the USA also make longer cylinders that dont require spacers ,
Cheers
"Goliath"
Big motor-Big brakes-Big wheels-Big FUN !!!!
Old October 23rd 2003, 10:14
Re: Longer Barrels
Cheers
Does Heads up performance have a web site?
Old October 25th 2003, 00:19
Bruce2 Bruce2 is offline
First off, extra long Type 1 cylinders are only made in 94mm bore. Nothing is made for 90.5mm.
Secondly, you don't need longer cylinders when your stroke is only 82mm. The standard CIMA cylinders are plenty long enough. The length of the connecting rod has nothing to do with the required cylinder length. All you need is a thick spacer under the cylinder. Or better yet, shorter rods.
