Old November 7th 2003, 22:22
Ian66 Ian66 is offline
Which wheel spacers do I need?
Hey all,
I've just finished the conversion of a set ot '86 944 Turbo fron brakes for my K+L suspension '66 beetle, but have just found out my 15"x6" fuch wheels will not clear the calipers...
What sort of clearence from the caliper to the wheel should I be aiming for?
Or what thickness spacers should I be using?
Cheers,
Ian Swinkels
Old November 8th 2003, 07:14
matara's Avatar
matara matara is offline
Hey Ian,
I'm thinking of doing that brake conversion myself. Can you tell me how you did it, and how much it increases your track on the front?
Sydney, Australia
Old November 9th 2003, 18:49
My conversion works a little diferent than most.
I've used 86 944 turbo hubs, calipers and 298mm turbo disks.
To convert the hub, I've had a machine shop make up some bear bushes to increase the inner and outer bearing sizes so I can use standard porsche bearings.
The caliper required about 2mm to be shaved off the top caliper bolt mount so it would not interfere with the brake pad in the caliper.
Then as for the caliper, I've cut off the top mount. Then made up a piece of 6mm thick aluminium to fill the gap between the caliper and the spindle caliper mount. After carefully marking it all out I've then had an aluminium welder build up a new mounting point.
Then I've smoothed off the whole welding job, sand blasted, primed and painted the calipers.
They now look factory, except for the two mounting points will directly fit a vw spindle now.
To fit on the porsche fuch wheels It will require 14mm spacers and 60mm wheel studs from the looks of it, but I was still curious what everyone else was using...
Cheers,
Ian
