Old January 6th 2004, 13:49
kiwivw kiwivw is offline
Yes, Its all your fault!
Thats probably why i keep emailing you.
Thanks Rich.
Cheers
Craig.
Old May 25th 2005, 13:32
rip's Avatar
rip rip is offline
sorry for bringing up an old post but....
just wondering what master cylinder are you using with these Rx7 brakes?
thanks
Rip
Old May 26th 2005, 17:55
Smile
I'll be using a Tilton dual master cylinder setup for these and the 944T rears.
Cheers
Craig.
Old August 11th 2005, 16:46
rip's Avatar
rip rip is offline
kiwivw, was wondering how did you hook up the front brake lines? I was working on mine and got three solutions:
1) find a invert metric to a bubble metric adaptor
2) use a intermediate metal brake line from the caliper to the rubber hose, that adapts the different flares
3) try to use a rubber brake line from a mazda then use a intermediate metal brake line from the mazda rubber hose to the master cylinder.
I couldn't find the brake line adaptor, I've been looking, cannot find one.
The problem I have with the second one is mounting a bracket to hold the metal line strudy. It's sort of tough not a lot of room there. I mean you want to keep the line clear from the suspension plus have enough slack for travel.
I think that leaves the third one, here I just gotta find a rubber brake hose that works. Figured the Rx7 was a good place to start, duh. But other than the earlier sliding caliper rubber hose the brake hoses are female/female.
So it brought up the question how did you do it?
Rip
