9th is looking good sofar.
Rob. |
I can not make it either day....unless I find a babysitter.
Maybe I can try for the 9th. Alex |
Excitement is Building, Vroom, Vroom
Well things are being to move along nicely, this last weekend my friend and
I re-intalled "my" rebuilt 1641 engine into the beetle. After some extra work and struggle with bell housing and engine alignment we finally got it right and together she went. We double checked everything, did a dry run to get oil pressure up to 20 psi and then called it a day. Tonight after re-installing the miscellaneous components, removal and re-install the distributor drive gear and timing set-up we were really. Another check, little gas primer (fire extingusher nearby) it was time to fire her up. After a couple of tries and primer we have ignition, and lots of oil smoke since we well lubricated the cylinders, etc to make sure we were good for start up and initial brak in. Crank her up and VROOM - VROOM we are in business and smiling from ear to ear, we did it and she even sounds decent ! (Not that we were surprises or anything but just been about twenty years since my last engine rebuild - 327 Chev power). Looking forward to our next meeting on the 9th. and may even bring along some pictures or Video clips. There really is light at the end of the tunnel and it's not a freight train a comin'. See you all soon. Allan Mayhew (the old guy)
1972 Super Last edited by ajracer; March 2nd 2004 at 01:23. |
Alan,
That's excellent... So you'll be driving for sure this summer ! Rob. |
i'll be there on the 9th
'72 super '65 bus '52 split |
Ales, If you can make it, can you bring that surge tank if you still have it ?
Thanks, Rob. |
so its the 9th?
GL ghia restoration: http://s473.photobucket.com/albums/r...20restoration/ __________________________________________ |
