Old April 7th 2004, 10:30
Bugnutz's Avatar
Bugnutz Bugnutz is offline
Found some at racer's edge
Guys,
I found that Racer's Edge has Delrin inner and outer bushings for the 944. I had been considering filling part of the 944 cast aluminum spring plate retainers with thickened epoxy and using the VW urethane outer bushings, but maybe these delrin bushes are the way to go. The wider bushings in the 944 cast retainers should give a lot more support to the spring plate and therefore less deflection of the trailing arm.
http://www.racersedge-inc.com/bushparts.html
If I can find a suitable hunk of delrin plastic, it may be possible to make a set on a lathe.
The delrin bushings would be a lot harder than the urethane, but the Weltmeister bushings that Pelican sells are way hard, they are pour-molded out of polycarbonate!!! (that's Lexan)
Regards, Mark.
Originally Posted by ricola
I got mine form pelican and they were fine, I prefer using a cut down 944 cove as the bushing gives much better support to the spring plate.
To pre-empt the hassles you will have with getting the old 944 bushing off (it's bonded). Use a knife to get the majority off and then an angle grinder with wire wheel attachment. Worked great for me after spending most of a day trying to burn it off!
Rich
