Old October 16th 2002, 05:23
blkglook blkglook is offline
Question 17"and 18" rims
When using 17" and 18" rims and tires do you have to use wider than stock fenders?
Old October 16th 2002, 05:45
bren's Avatar
bren bren is offline
nope.. not unless they are stupidly wide or have an unsuitable offset...
Old October 16th 2002, 07:15
NYBugman1972's Avatar
Also depends on what car you have. Super's require a narrow strut/coil-over, like the MaXX struts from Topline. Standards may require a narrowed beam. Again, this all depends on offset and width.
I am about to put 17x7 and 17x8.5 Boxster turbo twist wheels on my 72 super. I have stock front fenders with MaXX struts. In the rear, I have 1.25" wider fenders and a 1" spacer. I also have to shave a few things down for clearence.
Tell us what width and offset you want, and we can help figure out what you need.
Mike Serrone
///BrooklynAutoRennen
Old October 16th 2002, 08:51
cre8iv1's Avatar
cre8iv1 cre8iv1 is offline
I am planning on running 17x7 et40 up front with maxx struts with stock fenders and 18x8.5 et19 in the rear with a 2" wider fender... should work with no spacers if my math is correct.
See ya,
Brett
72 super vert...in progress!
Old October 16th 2002, 10:28
bren's Avatar
thats what i mean.. width and offset are critical.. for example the rims on the car below (Vauxhall VX220 in the UK, opel speedster in europe) are 5.5x17 up front and 7.5x17 in the back and are fitted as stock with 175/55/17 and 225/45/17 respectively.. by my reckoning these would fit a super without the need for max struts or wider wings (fenders to you) making life VERY easy.. hubs drilled to 5x100 PCD being the only requirement...
