Hello,
I run the wide turbo alu arms as well and have 8x16 993 rims with ET70 and 225/50/16 tires in the back. I needed wings that were 5cm wider, but Kerscher only makes either 3cm or 7cm wider wings. Therefore I used the 7cm wider wings (inside and outside widened) and used a porsche spacer which was + 2,5cm. I hope this gives you some reference. Greetings, Walter |
So with ET30 on 8" wheels, I would need a 5cm + 4cm!!
WOW!! That alot of rear wing!!
nice tail ligths zen! truly awsome.
i need to get back in the scene
73' 1303s el vindows, ford 39's, ford mondeo indicator lights, ats 7" all around, 205-15-50 , 225-15-50, it spits flames through a superstreet exhaust (they are long!) :help:
